 Post subject: WD Marvell modules CRC
PostPosted: August 10th, 2011, 16:14
In older WDC-based drives the SA modules used simple 8-bit checksums; however, the newer Marvells use CRC-32 which can use different algorithms and parameters. Do you know which one is used in Marvell modules? I.e. how can one calculate the CRC on his own - e.g. when fixing a corrupt module?
Thanks! 8)
 Post subject: Re: WD Marvell modules CRC
PostPosted: August 13th, 2011, 14:11
Solved ;)
Users browsing this forum: fouad19764 and 195 guests
