 Post subject: Recover partition Table on External HDD
PostPosted: August 14th, 2011, 17:07
I Have an external HDD to 500GB.
Randomly performed on him the command "diskpart->clean" as a result of exiting information about a single partition.
Tried to Find and Mount, she quickly finds a deleted partition, but access is only in read-only.
TestDisk runs long, apparently found nothing.
Is there any software that can completely restore the partition table to disk? That is, find the deleted section, and record information about it on the HDD. The data is intact, but copy them to another location is not possible.
 Post subject: Re: Recover partition Table on External HDD
PostPosted: August 14th, 2011, 23:46
if partition find & mount shows the data is it possible to copy all the files to another location , the format the drive & place the files back. might be easier than trying to repair the partition. just an idea
PostPosted: August 15th, 2011, 5:17
Easeus
Partition Wizzard Home Edition
The free versions allow for partition scan & repair (I think). Remember you should backup the drive as an image to another before you run repair tools otherwise the final results would be at your own risk!
Users browsing this forum: gold6565, Google [Bot] and 128 guests
