 Post subject: Where is the ROM chip on that PCB?
PostPosted: August 25th, 2011, 10:13
I guys,
I feel like a stupied, but where is the rom chip on that WD WD10EACS-00D6B1
The drive lable:
http://img850.imageshack.us/img850/2531/wdlable.jpg
The PCB itself
http://img546.imageshack.us/img546/1493/romchip.jpg
* I have the right doner for that drive, but where is the ROM chip?
Many Thanks!
 Post subject: Re: Where is the ROM chip on that PCB?
PostPosted: August 25th, 2011, 10:21
Firstly whats the fault?
The rom is on the square chip in the middle with the big M on it.
Not DIY will need a PC3000, Atola or Salvation Data doctor to write the contents to the donor.
Loki.
PostPosted: August 25th, 2011, 10:26
Loki.
So luckily I have PC3000 and Atola 8)
The PCB is dead BUT the heads are alive.
I see a chip which look like a small rom chip but not sure that it is.
IS it with the Q2 mark on the PCB itself?
PostPosted: August 25th, 2011, 10:27
It's embebeded ROM, so it's inside CPU.
Is your patient PCB damaged?
What's the issue with it?
PostPosted: August 25th, 2011, 10:32
ROM info is stored in Marvell chip (processor)
www.datarecoveryne.com
PostPosted: August 25th, 2011, 10:34
Sorry for my ignorance but have you tested the diodes (D3, D4) & Resistors (64 & 67) ?
As I stated befor the ROM is the big square chip with the big M on it. (as the U12 is empty)
& yes you are lucky to have a PC3000 wish I had one :(
Loki
PostPosted: August 25th, 2011, 10:37
Very bad, or not? :wink:
The PCB itself stay cold when power is connected. I have the following doner for that case:
http://img846.imageshack.us/img846/1184/doner.jpg
PostPosted: August 25th, 2011, 10:46
So you can use donor PCB to access at least SA tracks, and from that point on you can rebuild ROM from SA data.
PostPosted: August 25th, 2011, 13:41
Yes, dmarques is correct
Connect the donor PCB and follow the instructions in PC3000-UDMA to restore your ROM from the SA tracks.
PostPosted: August 25th, 2011, 17:20
Hi, Thank you for your advices, I will try and hope for good results..
Hi Pcimage, thank you for your respond too :)
PostPosted: August 25th, 2011, 20:53
Good luck my friend :-)
Should be straightforward solution with UDMA
Users browsing this forum: No registered users and 147 guests
