 Post subject: Drive recovery from unreadable P-list module
PostPosted: August 23rd, 2011, 15:47
Any gurus out there that can recover data from a WD800BB with an unreadable P-list? All other mods, except for one SMART mod, can be read correctly.
 Post subject: Re: Drive recovery from unreadable P-list module
PostPosted: August 23rd, 2011, 15:54
Self Scan is the key
PostPosted: August 23rd, 2011, 17:17
Einstein is correct.
Another clue..... "logs" :-)
PostPosted: August 23rd, 2011, 18:26
What does it mean "unreadable p-list"?
PostPosted: August 23rd, 2011, 19:20
If you do a self-scan on the drive itself, won't it erase the data?
http://www.datasaversllc.com
PostPosted: August 24th, 2011, 9:24
Yes it will, but that's not what is being suggested. (Well at least I hope so, I can only speak for myself!)
PostPosted: August 24th, 2011, 9:28
pcimage is correct, but P-List module here should not be important if translator modules are OK.
PostPosted: August 24th, 2011, 10:15
I understood what you meant (and what was implied), but I'm concerned that another reader may not . . .
PostPosted: August 24th, 2011, 18:31
Ah, yes. I suppose it be construed as "run self scan" to a newbie.
Point taken.
PostPosted: August 25th, 2011, 12:40
When i said: Self Scan is the key
you need to be an expert to know what mean
i guess some of the replies here know exactly what am talking about
but it all starts there in ur case here
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 138 guests
