 Post subject: replacing PCB for recovery
PostPosted: September 8th, 2011, 2:47
Evening everyone. im about to send a harddrive in for recovery. But first i want to locate a similar drive so i can hand it in with the recovery.
My question is: what exactly do i need to match up when searching for the same harddrive?
The drive in question is a Hitachi Deskstar
MODEL: HDS722580vlat20
CAPACITY: 80.0GB
P/N 13G0501
LBA: 156.250.0000 SECTORS
ATA/IDE
RPM :7200
MLC: BA1184
CHS: 16383/16/63
DS/N TH-0N0785-12561-49C-10KV
DP/N 0N0785
C/O TH
A12311
REV A000
sticker on the back reads
14R9220BA1040_K2Q4360792
I've found several drives on ebay with the matching model: HDS722580vlat20, but none of the other pieces match. I've also found a few sites that might have this item (for a lot of money).
In case anyone is wondering what is wrong with the drive. I ever so slightly nudged it reaching for something. now it just clunks over and over again.
Any information would be greatly appreciated.
Regards.
 Post subject: Re: replacing PCB for recovery
PostPosted: September 8th, 2011, 2:57
It won't be a PCB problem.
Also any decent DR firm will have spare heads for this common drive.
PostPosted: September 8th, 2011, 3:00
Thanks for the response pcimage. most of the data recovery places i called mentioned they may need to order the drive in. so i just figured anything i could provide them with would make this painful process faster.
Good to know it's a common drive though.
PostPosted: September 8th, 2011, 4:02
Well the most important part is : Proper Diagnose 90%
having another similar is good but will not ALWAYS help
good luck
PostPosted: September 8th, 2011, 20:33
What companies did you call?
PostPosted: September 9th, 2011, 10:09
Heya m8. Ill pm my cell to u and explain the situation. The description that you are giving sounds more mechanical then electronic. Also prepare urself for killer prices we have in the area =) There are some ppl on this forum ( Luke and Jono to name a few ) who charge less then our company.
Users browsing this forum: Bing [Bot] and 71 guests
