 Post subject: Help needed : how to recover directory tree on hdd from NAS
PostPosted: September 11th, 2011, 23:07
I had a very unpleasant (to say the least ) event : by mistake I formatted the harddrive with my mp3 and flac files which was in D-link DNS-323).
I've inserted the second drive, but by mistake I formatted harddrive that already was there. So that it just essentially did the exact same partitioning which it was, but obviously all the files and directories are gone.
I scan it with one of the "undelete" tools and discovered a lot of files, but obviously the original names and directories are gone.
Is there any sophisticated way to restore original directories tree, considering the fact that it formatted/partitioned the drive exactly as it was before ?
Any help will be appreciated. I spent many monyhs digitalizing my CDs and I don't want to repeat the process.
Anybody had similar experience and can recommend any tools Windos or Ubuntu ( I have dual boot - Win7 / Ubuntu on my laptop and XP / Ubuntu on my desktop)
Thanks in advance
 Post subject: Re: Help needed : how to recover directory tree on hdd from
PostPosted: September 12th, 2011, 3:52
So you had just one drive on your NAS? And then you inserted a new one and formatted the old one?
Did you use that "undelete" app to scan directly the NAS? Or did you remove the drive and scan it?
PostPosted: September 12th, 2011, 13:35
That's correct. Essentially it formated it to the same partition structure.
I removed drive immediately and used couple of undelete applications which "discovered" a lot of files, but as I mentioned
it's just individual files with no meaningful names at all. Is it some how possible to resotre at least partually the old directory tree ?
I didn't do any operations after I formatted the drive.
Thanks for any advices
PostPosted: September 12th, 2011, 15:41
Do you know how to work with an hex editor?
If so, open up the drive and check what File System is it.
That will be your first step.
PostPosted: September 12th, 2011, 16:39
Hi !
I know this already : it's formatted as ext2 and it was ext2 as well.
Do you mean some other things to check, when you mentioned hex editor.
I have no problem to use it if necesasary
Thanks for your help
PostPosted: September 13th, 2011, 4:36
So use a software that supports Ext2 to scan your drive and check the results to see you can get a structure.
PostPosted: September 13th, 2011, 15:17
like R-Studio for example, download the demo and try
PostPosted: September 13th, 2011, 18:05
Einstein and Dmarques
Thanks for pointing out on R-studio.
I'll try it today evening
Users browsing this forum: No registered users and 82 guests
