 Post subject: Hitachi IC25N060ATMR04-0 locked...
PostPosted: October 15th, 2006, 3:09
anybody knows how to unlock hdd hitachi model : IC25N060ATMR04-0 ?
 Post subject:
PostPosted: October 15th, 2006, 12:10
unlock is the hdd locked with a password if yes then which kind of password :
Master password
User password
 Post subject: Re: Hitachi IC25N060ATMR04-0 locked...
PostPosted: October 16th, 2006, 13:30
You have at choice :
1. Hot-Swap
2. PC3000 PCI
Regards .
PostPosted: October 16th, 2006, 15:12
1. Hot-Swap
2. PC3000 PCI
Regards .
1. not a choice for this drive.
 Post subject:
PostPosted: October 17th, 2006, 8:47
Still can't unlock this drive, i don't a master password, what must i doing to unlock ... ?
don't have a pc3000 pci... pc3000 isa can do it?
 Post subject:
PostPosted: October 17th, 2006, 12:42
When hot swap does not act with these disks ,
then becomes only PC3000 PCI .
PC3000 ISA does not serve these disks !
Regards .
 Post subject:
PostPosted: October 24th, 2006, 17:15
AFF will unlock that drive
 Post subject:
PostPosted: October 25th, 2006, 8:19
hi,
http://www.hdd-tools.com/products/rrs/download/
8)
 Post subject:
PostPosted: October 25th, 2006, 12:17
You saw the service of this disk ( Hitachi IC25N060ATMR04-0 ) in this programme ?
Regards .
 Post subject:
PostPosted: October 26th, 2006, 9:12
Regards .
Sorry my mistake Hitachi is not supported by AFF
 Post subject:
PostPosted: November 9th, 2006, 15:46
I do not think Hot Swap will work because of incompatibility between the NVRAM chips on the PCBs. Using PCI PC3000 and using a Probe to short specific points on the PCB (explained in PC3000 PCI manual) is the onyl sure way to clear this password.
PostPosted: August 28th, 2011, 22:58
I have a : Hitachi laptop hd locked . Tried a lot of software to unlock . Pc3000 is too expensive , is there a way to short the points without the kit and use other software , or alter details of similar hd to hotswap
PostPosted: August 29th, 2011, 4:13
No, afraid not :-(
PostPosted: September 13th, 2011, 12:03
Hi , there may be a solution that does the above and allows you to short the points
http://www.badcaps.net/forum/showthread.php?t=10357
Unlock ATA password Hitachi Hard Drive
Now I know if hitachi hard drives can be unlocked via a 9000.00 piece of equipment called PC-3000 we also can do it with something readily available to the general public.
It appears that they use a "Probe" which may just be some hardware hack or jumper to cause password flag to be erased when certain code is sent to the drive the force the execution of this code by either applying power or resistance or simply jumping these two pads.
How I think it works:
The probe causes a write flag to be set and allows the password to get over written with a new one or maybe the write head is forced to confirm password from a different location on the hard drive when this jumper is enabled a writeable area thus when request to unlock is preformed the fake location is read password is correct and lock flag gets removed.
Tools needed for testing:
P4 PC with ide drive.
Ultimate boot disk
2.5 to 3.5 ide adapter.
toggle switch
Jumper wire
Hook up toggle switch to 5v power so you can power off and on your hard drive manually.
Hook up drive to PC as the only hard drive on primary and a cd/dvd/bd rom drive on secondary ata.
Set bios to boot from CD first.
Insert ultimate boot cd and load ata password utility on there.
Now we can send info and power down set jumper and power up. If done right we may be able to overwrite the password.
Use this as a guideline for unlocking!
http://www.youtube.com/watch?v=X5UczkKoi20
Download this video entering in the above address at www.keepvid.com
Any hardware gurus out there with locked hdd's?
PostPosted: September 13th, 2011, 15:12
Ultimate boot disk
toggle switch
Jumper wire
Download this video entering in the above address at http://www.keepvid.com
in order to fix ur problem u will need a loan to follow this video too high (cost)
good luck
PostPosted: September 13th, 2011, 15:16
? the video uses pc-3000 hardware and software , thus the need for a work around as pointed to in my previous point , if its correct all we need to find out what to short the hdd as some things might break the hdd. but if it works then it would probably be 30$ or less . As opposed to the thousands of dollars for 3000 hardware /software .
PostPosted: September 13th, 2011, 15:21
"That jumper tool in the video, are these resistors, diodes or something else on the board? Just to make sure that a blank wire won't fry the board.."
or just a jumper wire and toggle switch like he advised .
PostPosted: September 13th, 2011, 16:40
The probe doesn't remove the password
PostPosted: September 13th, 2011, 18:35
The post indicates other software might work once the points are shorted or even with the software in video . Unless you mean that shorting the points + software isn't enough and a 3rd hardware interaction is required ?
PostPosted: September 14th, 2011, 9:34
Well, you need the hardware in order to use the software in the video.
Users browsing this forum: No registered users and 108 guests
