 Post subject: Dell 2850 Predictive Failure Physical Disk 0:4 - Which Drive
PostPosted: September 18th, 2011, 14:55
A friend has a Dell 2850 server that is used for data storage. Drives slots 0 & 1 are Raid 1 and 2-5 are Raid 5. In the event viewer (Windows 2003) there are repeated Event ID 2094 messages with a description of Predictive Failure reported: Physical Disk 0:4 Controller 0, Connector 0.
There aren't any add-in controllers that I'm aware of.
I'm an HP guy, not Dell. Is it correct to assume this is the drive in slot 4? Or is it?
 Post subject: Re: Dell 2850 Predictive Failure Physical Disk 0:4 - Which D
PostPosted: September 18th, 2011, 15:48
To be certain, you should install the Dell OpenManage utility.
Alternatively, enter the PERC management utility by pressing Ctrl + M during startup.
Data Recovery Ireland
Users browsing this forum: No registered users and 96 guests
