 Post subject: Seagate 7200.10 pins broken
PostPosted: September 20th, 2011, 20:07
first of all i'm new here.
Got a Seagate Barracuda 7200.10 320GB. I needed to change the PCB, but the connector pins from PCB to HDD are broken, The brown connector with that screw which is set on the pins is also broken.
Any way to fix the pins, or any other solution?. The data inside should be all ok.
-Thanks-
 Post subject: Re: Seagate 7200.10 pins broken
PostPosted: September 20th, 2011, 21:25
Can you take a higher resolution picture, please?
Users browsing this forum: No registered users and 116 guests
