 Post subject: Seagate Barracuda ES.2 Busy
PostPosted: September 20th, 2011, 10:16
Hello Gurus. Can anyone please help me out of the issue. I saw many posts here about the ES.2 busy issue and tried the methods mentioned, including shorting the read channel, with no luck. It just gave me:
LED: 000000CC FADDR: 0024AFF
Ctrl + z does not work in terminal;
PC3000 busy solution gave me: Error detecting HDD terminal baud rate.
Some body here successfully broke the loop by sending a signal to the write channel. How?
 Post subject: Re: Seagate Barracuda ES.2 Busy
PostPosted: September 20th, 2011, 10:20
The PC3K manual shows you what 2 points to short for the read channel.
Data Recovery Cape Town
PostPosted: September 20th, 2011, 10:29
Thank you, Nick_CT. I tried shorting the points at various time points. It did not work.
PostPosted: September 20th, 2011, 10:31
As it spins up short the points and keep them shorted, it should click about 11 times then spin down and come ready. Well that's on a 7200.11 I was working on yesterday anyway.
PostPosted: September 20th, 2011, 11:10
Yes, it always works with 7200.11. Seems ES.2 is a different story.
PostPosted: September 20th, 2011, 13:28
It's probably a timing issue with the shorting, persevere and you'll get there!
I always have so far!
PostPosted: September 20th, 2011, 13:39
I think I did it close to 20 times yesterday with that damn 7200.11...it's the worst when you're almost there and then lose grip of the shorting pin :lol:
PostPosted: September 21st, 2011, 14:28
tweezers and paper clip =))
Users browsing this forum: Google [Bot], nicola and 98 guests
