 Post subject: Another WD Encryption Issue
PostPosted: October 4th, 2011, 3:59
Hi all
I have an incoming WD10EADS which has a few bad sectors etc, nothing too serious.
Problem is, client removed and threw away the external casing so I only have the internal disk.
After looking disk into WinHex i can confirm 100% this is encrypted.
Can anyone advise as to which board should be used to read data off it?
I have tried with 2-3 boards i have here but none of them worked :(
 Post subject: Re: Another WD Encryption Issue
PostPosted: October 4th, 2011, 4:11
Man, from the day i saw your posts here i noticed your LOGO IMAGE .....
i do not think this is True in DR world (this is one)
#2, back to ur Question here:
Ask your Client, it is WD HDD, was it: Essentials.....etc
each one has its own pcb type
i have like 5 diff. types
if u don`t have it, buy new one for ur ref.
good luck
PostPosted: October 4th, 2011, 4:58
Hi
The logo is a joke, based on the famous "I kiss on the first date" 8)
Of course it is not real for DR. Just smile.
I asked client what type of ext. was it and their response was "it was a ... WD".. go figure.
Can you help with pcb numbers? I don't have a stock of these and i'd like to buy some.
Thanks!
PostPosted: October 4th, 2011, 8:27
PMed
PostPosted: October 4th, 2011, 8:50
And another one :wink:
Cheers/ Bosse
http://www.rescue-it.se
PostPosted: October 4th, 2011, 8:56
Thank you both.
As per drc's fantastic idea, this disk was identified as My Book Essential.
Now looking to find which board should be good for this model. :)
PostPosted: October 4th, 2011, 11:55
USB2.0 or 3.0?
Angel Data Recovery
PostPosted: October 4th, 2011, 14:20
I have some ideas, give me a shout on MSN :-)
PostPosted: October 5th, 2011, 2:41
DR-Kiev wrote:
USB2.0 or 3.0?
This is a USB 2.0.
I now have two good ideas as to how to get data off this, thanks to pcimage and jono-ats (appreciate it).
I have ordered a board that will most likely fit, once it arrives, i will try your suggestions and i will post results here.
Again, thanks for all the help! :D
