 Post subject: Dead Hard Drives and PCB boards
PostPosted: October 10th, 2011, 17:17
I have some old hard drives that have PCB Circuit board failure but would like them fixed for experimental purposes.
I have different branded drives that are 3.5 inch, IDE and SATA.
The hard drive details are below. Any PCB boards will be appreciated. If not then a dead hard drive that I can take the parts out would do.
IBM / Hitachi Deskstar
HDS722580VLAT20
HDS722540VLSA80
SEAGATE ST3400832A Barracuda
MAXTOR 7850AV
Western Digital WD WD400BD-75JMA0
ExcelStor J840
As you can see from the above list the drives are old and I am confident that there are readers who either have dead drives or boards that are stored away. if so and are willing to give them a second life that will be put to good use and be used for educational purposes.
please get in touch
I am based in the UK
Please PM me for more details
 Post subject: Re: Dead Hard Drives and PCB boards
PostPosted: October 11th, 2011, 12:06
An updated list of circuit boards wanted. Any help appreciated.
Dead hard drives or working ones and circuit boards
HDS722580VLAT20
HDS722540VLSA80
SEAGATE ST3400832A 400Gb
SEAGATE ST3500620AS 500.0GB
MAXTOR 7850AV
Maxtor VAM51JJ0
MAXTOR 31024H1 10.2GB
ExcelStor J840
PostPosted: October 11th, 2011, 19:00
Post in HARD DRIVE MARKET section or ask for moving.
P.s. I have almost all the drives you want, all working 100% but need DCM/alpha for match!
PostPosted: October 12th, 2011, 0:44
That's great news
Can you pm me more details
PostPosted: October 13th, 2011, 11:10
Yes but WHAT DO YOU EXACTLY NEED and what are the COMPLETE details of the drives ? Too many variables at play !
P.S. complete working drives fulfilling specific requirements , sourced as donor part are NOT CHEAP.
PostPosted: October 13th, 2011, 11:36
Dont need donor drives
just need circuit boards for the mentioned drives.
the drives are intact but need new pcb boards. all the drives are old ones so im sure that readers must have spare pcb bpards for these hard drives
please see below hard drive list that I need pcb boards for
HDS722580VLAT20
HDS722540VLSA80
SEAGATE ST3400832A
SEAGATE ST3500620AS
MAXTOR 7850AV
Maxtor Fireball3 VAM51JJ0 X2
MAXTOR 31024H1 (yah814y0) X2
ExcelStor J840
thanks
PostPosted: October 15th, 2011, 7:03
Thought I would bump this thread up a little
All the views for this read and no replies
The above list is the list of the hard drive model numbers not the pcb board numbers.
be good to get some replies and some help
thanks
Users browsing this forum: No registered users and 147 guests
