 Post subject: Lock drive or it is somthing else?
PostPosted: October 10th, 2011, 21:48
Hi all,
I have a WD drive Model: WD5000BMVW-11AMS0. This is 2.5 drive, USB only (USB 3.0).
The probelm is like that:
When I connect the USB cable to the system, the drive doesn't spin at all.
But when I put piece of paper between the heads connection and the PCB, the drive does spin.
Niether way the system doesn't recognize the drive.
PC3000 recognize the Rom Ver and heads map.
But doesn't recognize the drive too.
I wonder if the drive has hardware lock. If so, how can be solve?
Besides, is it possible to make USB 3.0 interface to sata interface?
Regards,
 Post subject: Re: Lock drive or it is somthing else?
PostPosted: October 11th, 2011, 2:00
as far as i know ur tool doesn`t support usb3 access
and this type of drives is smartware controlled
PostPosted: October 11th, 2011, 3:02
Sounds like preamp, but try another PCB first.
Users browsing this forum: No registered users and 100 guests
