 Post subject: Fujitsu 33.6gb Ultra 160 scsi adaptives?
PostPosted: October 12th, 2011, 9:16
I am planning on swapping out a bad pcb on this drive. Does anyone know which chip holds the adaptives? There doesn't appear to be the usual 8 legged rom on this board however there is a larger 40 pin lsi that is stamped with what could be a firmware version. Is this it?
Thanks,
GB
 Post subject: Re: Fujitsu 33.6gb Ultra 160 scsi adaptives?
PostPosted: October 12th, 2011, 9:40
If you google the IC part numbers you should be able to figure out which is which.
PostPosted: October 13th, 2011, 2:42
Upload a photo and/or tell us the markings on the most likely suspects.
Sometimes the markings omit the leading character(s), and this can hamper a Google search.
Users browsing this forum: Rendersmith and 120 guests
