 Post subject: PCB ST3500412AS FW CC32 100535704 REV B PCB
PostPosted: October 14th, 2011, 14:24
need this urgent. Data required from the hard rive very important wedding photos !!
 Post subject: Re: PCB ST3500412AS FW CC32 100535704 REV B PCB
PostPosted: October 14th, 2011, 14:32
Are you really confident about the diagnosis that you need a PCB, and that you can do all the necessary steps to replace it? If so, then this should really be in the Hard Drive Market section of the forum...
If you want advice about that diagnosis, then you should supply the current symptoms, what tests you have done and their results, and what changed / happened between it working OK, and now not working (in whatever way you explain as the symptoms).
PostPosted: October 14th, 2011, 14:34
sorry im a new member. how do i move it to the hard drive section? its been tested and 100% pcb problem.
PostPosted: October 14th, 2011, 14:41
You (or I) can't move it - we could request the mods to do that, but perhaps easier (since this thread is so short) is to let this thread die here, and for you to repost from scratch in the Hard Drive Market section.
Good luck!
PostPosted: October 19th, 2011, 4:34
This supplier includes a mandatory firmware ransfer:
http://www.hdd-parts.com/18000300-2.html
That said, sometimes there is an easy DIY fix. What is the problem with your board?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 96 guests
