 Post subject: Seagate ST9250410AS Momentus 7200.4 PCB problem?
PostPosted: October 12th, 2011, 5:05
Hi guys,
I got this drive Seagate ST9250410AS Momentus 7200.4 and when i power on in PC3000 the drive doesnt spin and give me this log in the terminal: "Bogus ISR".
Its the PCB that are damage?
Best regards,
Data Recovery Technician - If Data is important don't DIY without knowing the real problem.
 Post subject: Re: Seagate ST9250410AS Momentus 7200.4 PCB problem?
PostPosted: October 12th, 2011, 5:12
Or the motor...
Lemmy
PostPosted: October 12th, 2011, 5:24
Good point,
I'm going to open it to see if is the heads that are stuck our the motor blocked.
Thanks ici_lemmy
PostPosted: October 12th, 2011, 5:43
If not --> PCB
Lemmy
PostPosted: October 12th, 2011, 6:14
I Open it and the motor spin and the heads are in parking area.
I test the diodes from the pcb and they are fine, probably its any track that isnt passing voltage to the components.
PostPosted: October 12th, 2011, 6:39
A couple of comments...
infofaster wrote:
drive doesnt spin
infofaster wrote:
the motor spin
These two statements from you, seem to contradict each other. That makes it difficult for others to give you good advice :( You might get more accurate advice if you explain this apparent contradiction in your two statements.
That is just a wild guess, isn't it. :) I don't work with these drives, but based on the specific one line of terminal output which you have provided, then from my low-level programming background, I would not be making the same guess - at least not at the beginning. YMMV :) Providing the full terminal output might allow others (who work on this type of drive) to give you more suggestions.
PostPosted: October 12th, 2011, 6:56
When you wrote "motor spinn" I assume that is by hand...not by power, right?
I think you have a bad preamp.
Regards/ Bosse
http://www.rescue-it.se
PostPosted: October 12th, 2011, 7:23
Have you tested it with another PCB ?
PostPosted: October 12th, 2011, 8:00
I second mr_spokk's assumption.
Also I think when he said motor spins, he meant he tried to rotate platters with hand, and they rotate freely.
PostPosted: October 12th, 2011, 8:15
If so, try another PCB to see if it rotates, if not --> motor is dead !
Lemmy
PostPosted: October 12th, 2011, 8:23
In all my year in DR I have never seen a "dead motor", Bad bearings on Toshiba, Seagate and so...but never a dead motor.
But sometimes it has to be the first one :wink:
Bosse
PostPosted: October 13th, 2011, 2:56
Why didn't you just monitor the motor terminals with a multimeter or oscilloscope? Alternatively, you could have measured the motor current at the sense resistors.
If the TVS diodes were shorted, then the drive would not have powered up.
PostPosted: November 29th, 2011, 8:42
I figured out, the real problem was the PCB. I change the ROM Chip to donor PCB and the drive starts to spin and read the SA.
Data recovered! :D
Thank you guys for your Help.
Users browsing this forum: ccc, Google [Bot] and 231 guests
