 Post subject: In need of replacement PCB for a Western Digital hard drive
PostPosted: October 22nd, 2011, 22:46
I have a WD1001FALS SATA hard drive that has damaged SATA terminals, I either need to replace the PCB (WD 2061-701622-800-02P) or have someone replace the SATA terminals on my PCB.
Please contact me if you are able to help! Thanks :)
 Post subject: Re: In need of replacement PCB for a Western Digital hard dr
PostPosted: October 22nd, 2011, 23:05
If the SATA power connector is damaged, then you could hard-wire a 4-pin Molex connector to the +12V and +5V pins on the PCB. The +3.3V pins are not used.
http://pinouts.ru/Power/sata-power_pinout.shtml
http://pinouts.ru/Power/BigPower_pinout.shtml
Users browsing this forum: No registered users and 58 guests
