 Post subject: HD problem. Can I replace PCB?
PostPosted: April 8th, 2012, 21:53
I have a HP laptop with has two Toshiba hard drives.
One of them is not spinning anymore.:
MK3256GSY
HDD2E62 F VL01 S
S/N Y9FCF07ES HS1 EC.A
(CYL16383.H16.S63)
320GB (LBA 625, 142, 448Sectors)
CT: 2AVYP0AUZY8OKM
REPLACE WITH HP SPARE
516349-001
7F09B4
Can I replace swap he PCB from the 2nd HD to the one with problems without any problems? I read smewhere on your forum each hd from Toshiba has a specific data and the PCB cannot be changed by replacing the PCB.
 Post subject: Re: HD problem. Can I replace PCB?
PostPosted: April 9th, 2012, 5:20
MK3256GSY
HDD2E62 F VL01 S
(CYL16383.H16.S63)
CT: 2AVYP0AUZY8OKM
516349-001
7F09B4
No, you cannot directly exchange the PCB on Toshiba drives. They have unique adaptive data programmed into them, even the serial number.
You may get lucky and find that the PCB has this in an 8-Pin external ROM which could be transferred, otherwise you definitely need pro assistance.
Please bear in mind that any DIY attempts may seriously increase the chances of data loss and it is entirely your decision as to whether or not to attempt them.
Good luck :-)
PostPosted: April 10th, 2012, 3:43
@Freek, if you upload a photo of the component side, someone will identify the "ROM" for you. There may also be a fuse that you can check.
PostPosted: April 10th, 2012, 19:16
Thank you for your reply
I have to get the PCB off the drive first. It has not the normal screws but more like a + screw but I cannot get it off with a normal philips so have to find the right tool first as I assume the ROM is on the back side of the PCB as on the face side there is not a single rom.
PostPosted: April 10th, 2012, 19:17
PCImage: Thanks also for your reply. I have sent you a quote request.
PostPosted: April 10th, 2012, 20:42
Freek wrote:
I assume the ROM is on the back side of the PCB ...
Yes, all the components are on the other side.
PostPosted: April 25th, 2012, 18:44
Hi PCImage
I sent you a price quotation request by filling in the form on your website but never got a reply!
regards
Freek
PostPosted: April 26th, 2012, 2:28
Freek wrote:
Hi PCImage
regards
Freek
Sorry about that, I will get someone to check for the enquiry and respond this morning for you.
I know our website was being updated recently and being moved to a faster server, so maybe something went wrong there. I'll PM you if we can't find the enquiry.
Thank you
Sean
Users browsing this forum: No registered users and 50 guests
