 Post subject: WD800BB - 60JKA0 Questions
PostPosted: December 1st, 2012, 16:43
In a moment of stupid I think I shorted out my HDD. I had the cover off my PC while it was plugged in and believe I inadvertantly pulled on the cables connecting the HDD. Now when the computer boots it gives a message that no HDD is found, I of course checked the cables to make sure they were not just loose and no dice. Could the PCB on the drive have gotten shorted out or some other component that I can swap out to boot up the drive and copy all files? I'm not sure what HD info is helpful, the model is WD800BB-60JKA0 and the DCM is ESBHCTJCA.
I've never attempted HDD recovery/repair but i'm fairly technically proficient just need some guidance - thank you in advance!!
 Post subject: Re: WD800BB - 60JKA0 Questions
PostPosted: December 1st, 2012, 16:50
Does the drive still spin?
PostPosted: December 1st, 2012, 19:35
Could be a PCB short/surge.
Like labtech says, you need to see if the drive is still spinning.
If not then a PCB replacement with a U12 ROM swap stands a good chance of fixing it,
PostPosted: December 4th, 2012, 19:37
How can I determine if it still spins? Is that a hook it up turn it on and feel for vibration thing or ?
PostPosted: December 4th, 2012, 19:44
Exactly, spin indication is through sound and light vibration.
Users browsing this forum: No registered users and 100 guests
