 Post subject: 7200.12 ERORR FIRMWARE CC38
PostPosted: August 2nd, 2010, 2:37
Hi guys,
I have a Seagate Barracuda HDD with the following specifications:
Seagate 160Gb 7200.12
Model : ST3160318AS
FW : CC38
No detect
I have tried with dku5:
F3 T>/1
F3 1>N1
F3 1>N1
Init SMART Fail
LED:000000CC FAddr:0024E2DB
what means this message?
someone please help me?
VERY HAPPY Email WITH ME: khoiphucdulieu@yahoo.com
 Post subject: Re: 7200.12 ERORR FIRMWARE CC38
PostPosted: August 4th, 2010, 8:21
用11代盘指令修复报错:
F3 2>/1
F3 1>N1
Init SMART Fail
LED:000000CC FAddr:0024EE4
接COM线:先用LBA为0故障的M0指令来修复输入N1报错的问题,修复完后,再在/1级下输入N1来修复SMART故障导致的不认盘故障
PostPosted: August 5th, 2010, 5:25
Same problem here. Have you find a solution ?
PostPosted: August 5th, 2010, 8:41
slj.c d k gdfdxgk b
PostPosted: August 5th, 2010, 8:46
PostPosted: August 20th, 2010, 23:52
NEED DATA this hard drive
I"m try :
F3 T>V4
Reassigned Sectors List
Entries: 0000, Retrieved: 0000, Alts: 0000, Removed: 0000, Pending: 0000, GList:
0000, RList: 0000
Idx LBA PBA LLLCHS of LBA PLPCHS of PBA SFI Hours Msecs Status
BBM Mask
F3 T>V1
User Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI PBA
0 0 0 0 0 0 0 0 0 3 0
Head 0: entries 1 slips 0
Total Entries 1 Total Slips 0
F3 T>i4,1,22
F3 T>
Rst 0x08M
No HOST FIS-ReadyStatusFlags 2002A185
ASCII Diag mode
F3 T>m0,2,2,0,0,0,0,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 00, Max Certify Rewr
ite Retries = not supported
Init SMART Fail
=> someone please help me?
PostPosted: August 26th, 2010, 0:20
hardly anyone is able to solve the problem now.
i tried several com command and none works.
someone can deel with it,will he kindly show us some info?
PostPosted: August 26th, 2010, 0:21
T>V4 command views G-List,and i4,1,22 clears it.
PostPosted: August 26th, 2010, 1:02
Not true that nobody know. P.s. Clearing G is NOT ALWAYS A GOOD IDEA. I cannot say more.
PostPosted: February 27th, 2012, 11:51
Hi, i have the same issue.
always get a fail after trying to regen translator or clear smart. drive is BSY, but the calibrating souns is ok.
Init SMART Fail
LED:000000CC FAddr:0024E4A
any idea? BlackST, seems you have a solution?
thank you
PostPosted: February 27th, 2012, 11:56
Check the ENTIRE firmware for problems and IF the drive is ... "fully functional".
But this means you cannot do everything ONLY by terminal and an adapter !
PostPosted: February 28th, 2012, 6:05
Just because nobody publicly posted a solution here you think nobody can solve it?
Already in this case GLIST is cleared, so maybe there are other problems now anyway.
For this case I suggest you outsource it to somebody who can handle it.
Users browsing this forum: No registered users and 80 guests
