 Post subject: Seagate Momentus 7200.3 ST9320421AS
PostPosted: November 12th, 2011, 14:59
Ok can you guys let me know what you think. Turned off my laptop and the next day it wouldn't boot. So I took the hard drive and put it in my desktop and the computer recognizes it as a device and a disk, but when I open disk management it says it needs to be initialized, so i try to do that and it gives me an I/O error. So then I ran Seatools and it failed the short drive test (log posted below). Also the drive does spin and it is dead silent (no clicking, etc.). So what do you guys think is it the PCB or something else? Thank you all for the time and input. I posted pics below as well as one of the hard drive PCB.
Also in Seatools the SMART check passes.
SEATOOLS LOG
Model: ST9320421AS
Serial Number: 5TJ0MYH3
Firmware Revision: SD13
Identify - Started 11/12/2011 12:59:33 PM
Short DST - Started 11/12/2011 1:00:32 PM
Short DST - FAIL 11/12/2011 1:00:33 PM
SeaTools Test Code: 68DCE3E4
 Post subject: Re: Seagate Momentus 7200.3 ST9320421AS
PostPosted: November 13th, 2011, 6:11
99.99% NOT the pcb. On your desktop, do you connect through the sata port or via usb?
Basic question, are you trying to recover data off this disk, or you just want to repair it and use it? If the latter, i'd say you bin it and get a new one. If you want to recover data, trying to initialize the disk was not a wise choice. Check if disk identifies and displays contents using some linux live cd.
PostPosted: November 13th, 2011, 14:07
Ok i am doing SATA ports and i tried two different desktops using windows 7 and xp and ya i just want to get the files off. I unfortunately waited too long before getting a nas storage but i learned that lesson. I just want to try to save what is on the hard drive. But I'll try the Linux thing, what did initiatializing it in windows do? Thanks for your reply
PostPosted: November 13th, 2011, 14:43
Ok I tried Linux and it doesn't even see the drive in File Browser, is there something else or a tool I can try in Linux to try to get access to it? Thanks guys.
PostPosted: November 14th, 2011, 5:36
open a linux terminal and type dmesg
Then tell us what the output is. Does it see the drive?
I/O error could be caused by a lot of things, i am afraid you will need PRO help to recover your data.
And don't try anything funny like initialization, checkdisk etc, it will only make things A LOT worse.
PostPosted: November 15th, 2011, 19:42
Ok here is the dmesg output, I bolded what I could find about the hard drive, what do you think?
Initializing cgroup subsys cpuset
Linux version 2.6.27.12-170.2.5.fc10.i686 (mockbuild@x86-4.fedora.phx.redhat.com) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #1 SMP Wed Jan 21 02:09:37 EST 2009
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 00000000dfedf800 (usable)
BIOS-e820: 00000000dfedf800 - 00000000dfee0000 (reserved)
BIOS-e820: 00000000dfee0000 - 00000000dfee3000 (ACPI NVS)
BIOS-e820: 00000000dfee3000 - 00000000dfef0000 (ACPI data)
BIOS-e820: 00000000dfef0000 - 00000000dff00000 (reserved)
BIOS-e820: 00000000f0000000 - 00000000f4000000 (reserved)
BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
DMI present.
Phoenix BIOS detected: BIOS may corrupt low RAM, working it around.
last_pfn = 0xdfedf max_arch_pfn = 0x100000
x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
kernel direct mapping tables up to 38000000 @ 10000-15000
Using x86 segment limits to approximate NX protection
RAMDISK: 7fc15000 - 7ffff39d
Allocated new RAMDISK: 00978000 - 00d6239d
Move RAMDISK from 000000007fc15000 - 000000007ffff39c to 00978000 - 00d6239c
ACPI: RSDP 000F8310, 0024 (r2 HP-CPC)
ACPI: XSDT DFEE30C0, 003C (r1 HP-CPC AWRDACPI 42302E31 AWRD 0)
ACPI: FACP DFEE8300, 00F4 (r3 HP-CPC AWRDACPI 42302E31 AWRD 0)
ACPI: DSDT DFEE3240, 505D (r1 HP-CPC AWRDACPI 1000 MSFT 100000E)
ACPI: FACS DFEE0000, 0040
ACPI: MCFG DFEE8540, 003C (r1 HP-CPC AWRDACPI 42302E31 AWRD 0)
ACPI: APIC DFEE8440, 0084 (r1 HP-CPC AWRDACPI 42302E31 AWRD 0)
2686MB HIGHMEM available.
896MB LOWMEM available.
mapped low ram: 0 - 38000000
low ram: 00000000 - 38000000
bootmap 00011000 - 00018000
(9 early reservations) ==> bootmem [0000000000 - 0038000000]
#0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
#1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
#2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
#3 [0000400000 - 000097312c] TEXT DATA BSS ==> [0000400000 - 000097312c]
#4 [0000974000 - 0000978000] INIT_PG_TABLE ==> [0000974000 - 0000978000]
#5 [000009f000 - 0000100000] BIOS reserved ==> [000009f000 - 0000100000]
#6 [0000010000 - 0000011000] PGTABLE ==> [0000010000 - 0000011000]
#7 [0000978000 - 0000d6239d] NEW RAMDISK ==> [0000978000 - 0000d6239d]
#8 [0000011000 - 0000018000] BOOTMAP ==> [0000011000 - 0000018000]
found SMP MP-table at [c00f5f60] 000f5f60
Zone PFN ranges:
DMA 0x00000010 -> 0x00001000
Normal 0x00001000 -> 0x00038000
HighMem 0x00038000 -> 0x000dfedf
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
0: 0x00000010 -> 0x0000009f
0: 0x00000100 -> 0x000dfedf
On node 0 totalpages: 917102
free_area_init_node: node 0, pgdat c07f4a80, node_mem_map c1000200
DMA zone: 3951 pages, LIFO batch:0
Normal zone: 223520 pages, LIFO batch:31
HighMem zone: 682465 pages, LIFO batch:31
Using APIC driver default
ACPI: PM-Timer IO Port: 0x408
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
SMP: Allowing 4 CPUs, 2 hotplug CPUs
mapped APIC to ffffb000 (fee00000)
mapped IOAPIC to ffffa000 (fec00000)
PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
Allocating PCI resources starting at e0000000 (gap: dff00000:10100000)
PERCPU: Allocating 41372 bytes of per cpu data
NR_CPUS: 32, nr_cpu_ids: 4, nr_node_ids 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 909936
Kernel command line: initrd=initrd0.img root=CDLABEL=k12linux-f10-i386-20090203.18 rootfstype=iso9660 ro liveimg quiet rhgb BOOT_IMAGE=vmlinuz0
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
CPU 0 irqstacks, hard=c08a0000 soft=c0880000
PID hash table entries: 4096 (order: 12, 16384 bytes)
TSC: PIT calibration confirmed by PMTIMER.
TSC: using PIT calibration value
Detected 2800.739 MHz processor.
Console: colour VGA+ 80x25
console [tty0] enabled
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 3628156k/3668860k available (2740k kernel code, 39400k reserved, 1421k data, 412k init, 2751356k highmem)
virtual kernel memory layout:
fixmap : 0xffc57000 - 0xfffff000 (3744 kB)
pkmap : 0xff400000 - 0xff800000 (4096 kB)
vmalloc : 0xf8800000 - 0xff3fe000 ( 107 MB)
lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
.init : 0xc0816000 - 0xc087d000 ( 412 kB)
.data : 0xc06ad182 - 0xc0810620 (1421 kB)
.text : 0xc0400000 - 0xc06ad182 (2740 kB)
Checking if this processor honours the WP bit even in supervisor mode...Ok.
CPA: page pool initialized 1 of 1 pages preallocated
SLUB: Genslabs=12, HWalign=128, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Calibrating delay loop (skipped), value calculated using timer frequency.. 5601.47 BogoMIPS (lpj=2800739)
Security Framework initialized
SELinux: Initializing.
SELinux: Starting in permissive mode
Mount-cache hash table entries: 512
Initializing cgroup subsys ns
Initializing cgroup subsys cpuacct
Initializing cgroup subsys devices
CPU: Trace cache: 12K uops, L1 D cache: 16K
CPU: L2 cache: 1024K
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (24) available
CPU0: Thermal monitoring enabled
using mwait in idle threads.
Checking 'hlt' instruction... OK.
ACPI: Core revision 20080609
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
CPU0: Intel(R) Pentium(R) D CPU 2.80GHz stepping 07
CPU 1 irqstacks, hard=c08a1000 soft=c0881000
Booting processor 1/1 ip 6000
Initializing CPU#1
Calibrating delay using timer specific routine.. 5600.62 BogoMIPS (lpj=2800310)
CPU: Processor Core ID: 1
Intel machine check reporting enabled on CPU#1.
CPU1: Intel P4/Xeon Extended MCE MSRs (24) available
CPU1: Thermal monitoring enabled
x86 PAT enabled: cpu 1, old 0x7040600070406, new 0x7010600070106
CPU1: Intel(R) Pentium(R) D CPU 2.80GHz stepping 07
checking TSC synchronization [CPU#0 -> CPU#1]:
Measured 238 cycles TSC warp between CPUs, turning off TSC clock.
Marking TSC unstable due to check_tsc_sync_source failed
Brought up 2 CPUs
Total of 2 processors activated (11202.09 BogoMIPS).
sizeof(vma)=84 bytes
sizeof(page)=32 bytes
sizeof(inode)=340 bytes
sizeof(dentry)=132 bytes
sizeof(ext3inode)=492 bytes
sizeof(buffer_head)=56 bytes
sizeof(skbuff)=184 bytes
sizeof(task_struct)=3268 bytes
CPU0 attaching sched-domain:
domain 0: span 0-1 level CPU
groups: 0 1
CPU1 attaching sched-domain:
groups: 1 0
net_namespace: 840 bytes
Booting paravirtualized kernel on bare hardware
Time: 18:30:18 Date: 11/15/11
NET: Registered protocol family 16
No dock devices found.
ACPI: bus type pci registered
PCI: Found Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub without MMCONFIG support.
PCI: PCI BIOS revision 3.00 entry at 0xf1e60, last bus=2
PCI: Using configuration type 1 for base access
ACPI: EC: Look up EC in DSDT
ACPI: Interpreter enabled
ACPI: (supports S0 S1 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
pci 0000:00:01.0: PME# disabled
PCI: 0000:00:1b.0 reg 10 64bit mmio: [fdff8000, fdffbfff]
pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
pci 0000:00:1b.0: PME# disabled
PCI: 0000:00:1d.0 reg 20 io port: [ff00, ff1f]
PCI: 0000:00:1d.1 reg 20 io port: [fe00, fe1f]
PCI: 0000:00:1d.2 reg 20 io port: [fd00, fd1f]
PCI: 0000:00:1d.3 reg 20 io port: [fc00, fc1f]
PCI: 0000:00:1d.7 reg 10 32bit mmio: [fdfff000, fdfff3ff]
pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
pci 0000:00:1d.7: PME# disabled
PCI: 0000:00:1f.1 reg 10 io port: [0, 7]
PCI: 0000:00:1f.1 reg 14 io port: [0, 3]
PCI: 0000:00:1f.1 reg 18 io port: [0, 7]
PCI: 0000:00:1f.1 reg 1c io port: [0, 3]
PCI: 0000:00:1f.1 reg 20 io port: [fb00, fb0f]
PCI: 0000:00:1f.2 reg 10 io port: [fa00, fa07]
PCI: 0000:00:1f.2 reg 14 io port: [f900, f903]
PCI: 0000:00:1f.2 reg 18 io port: [f800, f807]
PCI: 0000:00:1f.2 reg 1c io port: [f700, f703]
PCI: 0000:00:1f.2 reg 20 io port: [f600, f60f]
PCI: 0000:00:1f.2 reg 24 32bit mmio: [fdffe000, fdffe3ff]
pci 0000:00:1f.2: PME# supported from D3hot
pci 0000:00:1f.2: PME# disabled
PCI: 0000:00:1f.3 reg 20 io port: [500, 51f]
PCI: 0000:01:00.0 reg 10 32bit mmio: [fa000000, faffffff]
PCI: 0000:01:00.0 reg 14 64bit mmio: [e0000000, efffffff]
PCI: 0000:01:00.0 reg 1c 64bit mmio: [f8000000, f9ffffff]
PCI: 0000:01:00.0 reg 24 io port: [df00, df7f]
PCI: 0000:01:00.0 reg 30 32bit mmio: [fbf80000, fbffffff]
PCI: bridge 0000:00:01.0 io port: [d000, dfff]
PCI: bridge 0000:00:01.0 32bit mmio: [f8000000, fbffffff]
PCI: bridge 0000:00:01.0 64bit mmio pref: [e0000000, efffffff]
PCI: 0000:02:08.0 reg 10 32bit mmio: [fdeff000, fdefffff]
PCI: 0000:02:08.0 reg 14 io port: [ef00, ef3f]
pci 0000:02:08.0: supports D1
pci 0000:02:08.0: supports D2
pci 0000:02:08.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:02:08.0: PME# disabled
pci 0000:00:1e.0: transparent bridge
PCI: bridge 0000:00:1e.0 io port: [e000, efff]
PCI: bridge 0000:00:1e.0 32bit mmio: [fde00000, fdefffff]
bus 00 -> node 0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp: PnP ACPI: found 11 devices
ACPI: ACPI bus type pnp unregistered
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
PCI: Using ACPI for IRQ routing
NetLabel: Initializing
NetLabel: domain hash size = 128
NetLabel: protocols = UNLABELED CIPSOv4
NetLabel: unlabeled traffic allowed by default
tracer: 772 pages allocated for 65536 entries of 48 bytes
actual entries 65620
ACPI: RTC can wake from S4
system 00:01: ioport range 0x4d0-0x4d1 has been reserved
system 00:01: ioport range 0x800-0x87f has been reserved
system 00:01: ioport range 0x880-0x88f has been reserved
system 00:07: ioport range 0x400-0x4bf has been reserved
system 00:09: iomem range 0xf0000000-0xf3ffffff could not be reserved
system 00:0a: iomem range 0xd1800-0xd3fff has been reserved
system 00:0a: iomem range 0xf0000-0xf7fff could not be reserved
system 00:0a: iomem range 0xf8000-0xfbfff could not be reserved
system 00:0a: iomem range 0xfc000-0xfffff could not be reserved
system 00:0a: iomem range 0xdfee0000-0xdfefffff could not be reserved
system 00:0a: iomem range 0x0-0x9ffff could not be reserved
system 00:0a: iomem range 0x100000-0xdfedffff could not be reserved
system 00:0a: iomem range 0xfec00000-0xfec00fff could not be reserved
system 00:0a: iomem range 0xfee00000-0xfee00fff could not be reserved
system 00:0a: iomem range 0xffb00000-0xffb7ffff could not be reserved
system 00:0a: iomem range 0xfff00000-0xffffffff could not be reserved
system 00:0a: iomem range 0xe0000-0xeffff has been reserved
pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
pci 0000:00:01.0: IO window: 0xd000-0xdfff
pci 0000:00:01.0: MEM window: 0xf8000000-0xfbffffff
pci 0000:00:01.0: PREFETCH window: 0x000000e0000000-0x000000efffffff
pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
pci 0000:00:1e.0: IO window: 0xe000-0xefff
pci 0000:00:1e.0: MEM window: 0xfde00000-0xfdefffff
pci 0000:00:1e.0: PREFETCH window: disabled
pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pci 0000:00:01.0: setting latency timer to 64
pci 0000:00:1e.0: setting latency timer to 64
bus: 00 index 0 io port: [0, ffff]
bus: 00 index 1 mmio: [0, ffffffffffffffff]
bus: 01 index 0 io port: [d000, dfff]
bus: 01 index 1 mmio: [f8000000, fbffffff]
bus: 01 index 2 mmio: [e0000000, efffffff]
bus: 01 index 3 mmio: [0, 0]
bus: 02 index 0 io port: [e000, efff]
bus: 02 index 1 mmio: [fde00000, fdefffff]
bus: 02 index 2 mmio: [0, 0]
bus: 02 index 3 io port: [0, ffff]
bus: 02 index 4 mmio: [0, ffffffffffffffff]
NET: Registered protocol family 2
Switched to high resolution mode on CPU 0
Switched to high resolution mode on CPU 1
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
checking if image is initramfs... it is
Freeing initrd memory: 4008k freed
apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
apm: disabled - APM is not SMP safe.
audit: initializing netlink socket (disabled)
type=2000 audit(1321381813.575:1): initialized
highmem bounce pool size: 64 pages
HugeTLB registered 4 MB page size, pre-allocated 0 pages
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
msgmni has been set to 1722
SELinux: Registering netfilter hooks
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
pci 0000:01:00.0: Boot video device
pci 0000:02:08.0: Firmware left e100 interrupts enabled; disabling
pcieport-driver 0000:00:01.0: setting latency timer to 64
pcieport-driver 0000:00:01.0: found MSI capability
pci_express 0000:00:01.0:pcie00: allocate port service
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
input: Power Button (FF) as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
ACPI: Power Button (FF) [PWRF]
input: Power Button (CM) as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1
ACPI: Power Button (CM) [PWRB]
fan PNP0C0B:00: registered as cooling_device0
ACPI: Fan [FAN] (on)
processor ACPI0007:00: registered as cooling_device1
processor ACPI0007:01: registered as cooling_device2
thermal LNXTHERM:01: registered as thermal_zone0
ACPI: Thermal Zone [THRM] (40 C)
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Non-volatile memory driver v1.2
Linux agpgart interface v0.103
Serial: 8250/16550 driver4 ports, IRQ sharing enabled
brd: module loaded
loop: module loaded
input: Macintosh mouse button emulation as /devices/virtual/input/input2
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
ata_piix 0000:00:1f.1: version 2.12
ata_piix 0000:00:1f.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
ata_piix 0000:00:1f.1: setting latency timer to 64
scsi0 : ata_piix
scsi1 : ata_piix
ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfb00 irq 14
ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfb08 irq 15
ata1.00: ATAPI: HP DVD Writer 640b, E193, max UDMA/33
ata1.00: configured for UDMA/33
ata2: port disabled. ignoring.
scsi 0:0:0:0: CD-ROM HP DVD Writer 640b E193 PQ: 0 ANSI: 5
sr0: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
sr 0:0:0:0: Attached scsi CD-ROM sr0
sr 0:0:0:0: Attached scsi generic sg0 type 5
ata_piix 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
ata_piix 0000:00:1f.2: setting latency timer to 64
scsi2 : ata_piix
scsi3 : ata_piix
ata3: SATA max UDMA/133 cmd 0xfa00 ctl 0xf900 bmdma 0xf600 irq 19
ata4: SATA max UDMA/133 cmd 0xf800 ctl 0xf700 bmdma 0xf608 irq 19
ata3.00: ATA-8: Hitachi HDP725050GLA360, GM4OA57A, max UDMA/133
ata3.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
ata3.00: configured for UDMA/133
ata4.01: failed to read native max address (err_mask=0x1)
ata4.01: HPA support seems broken, skipping HPA handling
ata4.01: ATA-8: ST9320421AS, SD13, max UDMA/133
ata4.01: 0 sectors, multi 0: LBA NCQ (depth 0/32)
ata4.01: configured for UDMA/133 (device error ignored)
scsi 2:0:0:0: Direct-Access ATA Hitachi HDP72505 GM4O PQ: 0 ANSI: 5
sd 2:0:0:0: [sda] 976773168 512-byte hardware sectors (500108 MB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1 sda2 sda3 sda4
sd 2:0:0:0: [sda] Attached SCSI disk
sd 2:0:0:0: Attached scsi generic sg1 type 0
scsi 3:0:1:0: Direct-Access ATA ST9320421AS SD13 PQ: 0 ANSI: 5
sd 3:0:1:0: [sdb] Very big device. Trying to use READ CAPACITY(16).
sd 3:0:1:0: [sdb] 0 512-byte hardware sectors (0 MB)
sd 3:0:1:0: [sdb] Write Protect is off
sd 3:0:1:0: [sdb] Mode Sense: 00 3a 00 00
sd 3:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sd 3:0:1:0: [sdb] Attached SCSI disk
sd 3:0:1:0: Attached scsi generic sg2 type 0
ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
ehci_hcd 0000:00:1d.7: setting latency timer to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:1d.7: cache line size of 128 is not supported
ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfdfff000
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 8 ports detected
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.27.12-170.2.5.fc10.i686 ehci_hcd
usb usb1: SerialNumber: 0000:00:1d.7
ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
USB Universal Host Controller Interface driver v3.0
uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
uhci_hcd 0000:00:1d.0: setting latency timer to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff00
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: UHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.27.12-170.2.5.fc10.i686 uhci_hcd
usb usb2: SerialNumber: 0000:00:1d.0
uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
uhci_hcd 0000:00:1d.1: setting latency timer to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000fe00
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb3: Product: UHCI Host Controller
usb usb3: Manufacturer: Linux 2.6.27.12-170.2.5.fc10.i686 uhci_hcd
usb usb3: SerialNumber: 0000:00:1d.1
uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
uhci_hcd 0000:00:1d.2: setting latency timer to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000fd00
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
usb 1-7: new high speed USB device using ehci_hcd and address 5
usb 1-7: configuration #1 chosen from 1 choice
usb 1-7: New USB device found, idVendor=058f, idProduct=6362
usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-7: Product: Mass Storage Device
usb 1-7: Manufacturer: Generic
usb 1-7: SerialNumber: 058F312D81B1
usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb4: Product: UHCI Host Controller
usb usb4: Manufacturer: Linux 2.6.27.12-170.2.5.fc10.i686 uhci_hcd
usb usb4: SerialNumber: 0000:00:1d.2
uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 16 (level, low) -> IRQ 16
uhci_hcd 0000:00:1d.3: setting latency timer to 64
uhci_hcd 0000:00:1d.3: UHCI Host Controller
uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000fc00
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 2 ports detected
usb 2-2: new full speed USB device using uhci_hcd and address 2
usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb5: Product: UHCI Host Controller
usb usb5: Manufacturer: Linux 2.6.27.12-170.2.5.fc10.i686 uhci_hcd
usb usb5: SerialNumber: 0000:00:1d.3
PNP: PS/2 Controller [PNP0f13:PS2M] at 0x60,0x64 irq 12
PNP: PS/2 controller doesn't have KBD irq; using default 1
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
rtc0: alarms up to one month
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.14.0-ioctl (2008-04-23) initialised: dm-devel@redhat.com
cpuidle: using governor ladder
cpuidle: using governor menu
usb 2-2: configuration #1 chosen from 1 choice
usb 2-2: New USB device found, idVendor=045e, idProduct=0719
usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-2: Product: Xbox 360 Wireless Receiver for Windows
usb 2-2: Manufacturer: Microsoft
usb 2-2: SerialNumber: FD392500
psmouse serio1: ID: 10 00 64<6>usb 4-1: new low speed USB device using uhci_hcd and address 2
usb 4-1: configuration #1 chosen from 1 choice
usb 4-1: New USB device found, idVendor=046d, idProduct=c509
usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 4-1: Product: USB Receiver
usb 4-1: Manufacturer: Logitech
usb 4-2: new full speed USB device using uhci_hcd and address 3
input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input3
usb 4-2: configuration #1 chosen from 1 choice
usb 4-2: New USB device found, idVendor=0471, idProduct=060c
usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 4-2: Product: BB+ Dongle(e.d)
usb 4-2: Manufacturer:
usb 4-2: SerialNumber: BEGK
usbcore: registered new interface driver hiddev
input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/input/input4
input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-0000:00:1d.2-1
input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.1/input/input5
input,hidraw1: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-0000:00:1d.2-1
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Plase use
nf_conntrack.acct=1 kernel paramater, acct=1 nf_conntrack module option or
sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
Using IPI No-Shortcut mode
registered taskstats version 1
Magic number: 3:545:544
scsi_generic sg0: hash matches
Freeing unused kernel memory: 412k freed
Write protecting the kernel text: 2744k
Write protecting the kernel read-only data: 1172k
udevd version 127 started
Initializing USB Mass Storage driver...
scsi4 : SCSI emulation for USB Mass Storage devices
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 5
usb-storage: waiting for device to settle before scanning
ISO 9660 Extensions: Microsoft Joliet Level 3
Unable to load NLS charset utf8
ISO 9660 Extensions: RRIP_1991A
squashfs: version 3.4 (2008/08/26) Phillip Lougher
usb-storage: device scan complete
scsi 4:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0
scsi 4:0:0:1: Direct-Access Generic USB CF Reader 1.01 PQ: 0 ANSI: 0
scsi 4:0:0:2: Direct-Access Generic USB SM Reader 1.02 PQ: 0 ANSI: 0
scsi 4:0:0:3: Direct-Access Generic USB MS Reader 1.03 PQ: 0 ANSI: 0
sd 4:0:0:0: [sdc] Attached SCSI removable disk
sd 4:0:0:0: Attached scsi generic sg3 type 0
sd 4:0:0:1: [sdd] Attached SCSI removable disk
sd 4:0:0:1: Attached scsi generic sg4 type 0
sd 4:0:0:2: [sde] Attached SCSI removable disk
sd 4:0:0:2: Attached scsi generic sg5 type 0
sd 4:0:0:3: [sdf] Attached SCSI removable disk
sd 4:0:0:3: Attached scsi generic sg6 type 0
kjournald starting. Commit interval 5 seconds
EXT3 FS on dm-0, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
type=1404 audit(1321381826.174:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
SELinux: 8192 avtab hash slots, 112836 rules.
SELinux: 8 users, 11 roles, 2652 types, 119 bools, 1 sens, 1024 cats
SELinux: 73 classes, 112836 rules
SELinux: Completing initialization.
SELinux: Setting up existing superblocks.
SELinux: initialized (dev dm-0, type ext3), uses xattr
SELinux: inode_doinit_with_dentry: no dentry for dev=dm-0 ino=36038
SELinux: inode_doinit_with_dentry: no dentry for dev=dm-0 ino=35916
SELinux: inode_doinit_with_dentry: no dentry for dev=dm-0 ino=35915
SELinux: inode_doinit_with_dentry: no dentry for dev=dm-0 ino=32769
SELinux: initialized (dev loop2, type squashfs), not configured for labeling
SELinux: initialized (dev loop0, type squashfs), not configured for labeling
SELinux: initialized (dev sr0, type iso9660), uses genfs_contexts
SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
SELinux: initialized (dev usbfs, type usbfs), uses genfs_contexts
SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
SELinux: initialized (dev mqueue, type mqueue), uses transition SIDs
SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses genfs_contexts
SELinux: initialized (dev devpts, type devpts), uses transition SIDs
SELinux: initialized (dev inotifyfs, type inotifyfs), uses genfs_contexts
SELinux: initialized (dev anon_inodefs, type anon_inodefs), uses genfs_contexts
SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
SELinux: initialized (dev proc, type proc), uses genfs_contexts
SELinux: initialized (dev bdev, type bdev), uses genfs_contexts
SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
type=1403 audit(1321381827.005:3): policy loaded auid=4294967295 ses=4294967295
input: Xbox 360 Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/input/input6
input: Xbox 360 Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.2/input/input7
input: Xbox 360 Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.4/input/input8
input: Xbox 360 Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.6/input/input9
usbcore: registered new interface driver xpad
xpad: X-Box pad driver
input: PC Speaker as /devices/platform/pcspkr/input/input10
lirc_dev: IR Remote Control driver registered, major 61
lirc_mceusb2: Philips eHome USB IR Transceiver and Microsoft MCE 2005 Remote Control driver for LIRC 1.48
lirc_mceusb2: Daniel Melander <lirc@rajidae.se>, Martin Blatter <martin_a_blatter@yahoo.com>
e100: Intel(R) PRO/100 Network Driver, 3.5.23-k4-NAPI
e100: Copyright(c) 1999-2006 Intel Corporation
e100 0000:02:08.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
e100 0000:02:08.0: PME# disabled
e100: eth0: e100_probe: addr 0xfdeff000, irq 20, MAC addr 00:17:31:ba:5e:a0
i801_smbus 0000:00:1f.3: PCI INT B -> GSI 19 (level, low) -> IRQ 19
usb 4-2: reset full speed USB device using uhci_hcd and address 3
lirc_dev: lirc_register_plugin: sample_rate: 0
lirc_mceusb2[3]: BB+ Dongle(e.d) on usb4:3
usbcore: registered new interface driver lirc_mceusb2
HDA Intel 0000:00:1b.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
HDA Intel 0000:00:1b.0: setting latency timer to 64
hda_codec: Unknown model for ALC883, trying auto-probe from BIOS...
ALSA sound/pci/hda/hda_codec.c:3021: autoconfig: line_outs=4 (0x14/0x15/0x16/0x17/0x0)
ALSA sound/pci/hda/hda_codec.c:3025: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
ALSA sound/pci/hda/hda_codec.c:3029: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
ALSA sound/pci/hda/hda_codec.c:3030: mono: mono_out=0x0
ALSA sound/pci/hda/hda_codec.c:3038: inputs: mic=0x18, fmic=0x19, line=0x1c, fline=0x1a, cd=0x0, aux=0x0
device-mapper: multipath: version 1.0.5 loaded
SELinux: initialized (dev binfmt_misc, type binfmt_misc), uses genfs_contexts
IA-32 Microcode Update Driver: v1.14a <tigran@aivazian.fsnet.co.uk>
firmware: requesting intel-ucode/0f-04-07
p4-clockmod: P4/Xeon(TM) CPU On-Demand Clock Modulation available
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ip6_tables: (C) 2000-2006 Netfilter Core Team
Bridge firewalling registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), uses genfs_contexts
ltspbr0: no IPv6 routers present
Bluetooth: Core ver 2.13
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.11
Bluetooth: L2CAP socket layer initialized
e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
ADDRCONF(NETDEV_UP): eth0: link is not ready
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Bluetooth: SCO (Voice Link) ver 0.6
Bluetooth: SCO socket layer initialized
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
SELinux: initialized (dev nfsd, type nfsd), uses genfs_contexts
NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
NFSD: starting 90-second grace period
eth0: no IPv6 routers present
fuse init (API version 7.9)
SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
SELinux: initialized (dev sda3, type fuseblk), uses genfs_contexts
PostPosted: November 16th, 2011, 5:21
This means that Linux sees your drive but can't mount it because it doesn't see correct capacity.
This means to me that there is either a firmware failure or (most likely) some mechanical damage to your drive.
I'd like to see what terminal outputs for this drive. Do you know how to connect your drive to a terminal?
If you know how to do this, post terminal output here.
Otherwise I think it is game over for DIY's. If you care about your data, consult a pro in your area. Ask member jono-ats.
Good luck.
PostPosted: November 16th, 2011, 11:28
I am very willing to try the terminal if there is a wallkthrough or something I can get info for it on, also I contacted jono-ats. Thanks for the info
Users browsing this forum: Google [Bot] and 122 guests
