 Post subject: Any one knows how to see WD PCB SN if match from HDD?
PostPosted: November 18th, 2011, 12:32
Hi HDD experts! :)
Does any one know how to see in PC3000 only with the PCB of WD1600BEVT-60ZCT1 the information off the HDD that match?
To see if the PCB was changed? Like model, Serial number from HDD that belongs?
The heads are damaged and i suspect that the PCB with ROM belongs to another HDD.
I know that in Seagate we acess T> and Crtl+L and we have the information off HDD that the PCB belongs.
If any one knows i was apreciated.
Thanks in advance.
Data Recovery Technician - If Data is important don't DIY without knowing the real problem.
 Post subject: Re: Any one knows how to see WD PCB SN if match from HDD?
PostPosted: November 18th, 2011, 12:56
WD does not has feature, but you can confirm if family is correct.
www.datarecoveryne.com
PostPosted: November 20th, 2011, 2:59
Compare the date codes on the chips against the date code on the label (or elsewhere).
If you need help identifying the date codes, upload a clear view of the chip markings.
PostPosted: November 20th, 2011, 21:48
Call WD's tech support and ask for Tier 2 support.
They can tell you if a particular PCB is the one that originally came with the drive.
Jon
http://www.datasaversllc.com
PostPosted: November 25th, 2011, 13:04
Thanks for your help.
fzabkar the data code of the PCB is WDC C 2004?
In the drive the date is 15 OCT 2005.
That means that the PCB doesn't match.
I'm i correct?
i doesn't know that was possible jono-ats, thanks for the tip. :)
PostPosted: November 25th, 2011, 16:29
Examine the chips on the PCB. They will have a YWW or YYWW (Year / Week) date code marking. For example, a code of 0543 indicates that the IC was manufactured in week 43 of 2005.
I believe there may also be a WWYY date code marked on the PCB in white.
If you need help, upload a detailed photo or scan of the component side of the PCB.
Users browsing this forum: No registered users and 341 guests
