 Post subject: Maxtor HD Won't Spin Up
PostPosted: November 18th, 2011, 11:45
Hi, new member here.
I'm working with a Maxtor DiamondMax Plus 9.
This HD won't spin up. Also, isn't recognized by the IDE PCIe adapter.
My questions are:
1. Does the HD have to spin up in order for it to be recognized. In other words, is the information provided by the PCB?
2. if the consensus is, the PCB may be bad, does it have to show some sign of a burn mark? Perhaps a bad chip?
3. Is a replacement PCB the most logical first step.
Thanks,
Randy
 Post subject: Re: Maxtor HD Won't Spin Up
PostPosted: November 18th, 2011, 11:49
1) Yes, HD has to spin up in order to be recognized.
2) Damage could be visible or might not be visible.
3) Yes, PCB would first logical step.
www.datarecoveryne.com
PostPosted: November 18th, 2011, 11:54
Hi, welcome.
1. Yes.
2. Not necesserily.
3. Yes, but sometimes you need to transfer ROM from the patient board to the donor. In DM9, it is not always necessary, though.
PostPosted: November 18th, 2011, 11:55
Ha, snap! :P
PostPosted: November 18th, 2011, 16:31
I have a replacement PCB coming. I'll post the results.
Randy
PostPosted: November 19th, 2011, 4:39
If it is a 60 GB / 6y060xxxxxx there can be bad news....
PostPosted: November 19th, 2011, 8:56
Do you think if it's 6l080xxxx or 6y080xxxx there will be another news ?
PostPosted: November 19th, 2011, 9:59
What's your question or is it a statement?
PostPosted: November 19th, 2011, 13:45
Thsi is the board I ordered:
http://www.hdd-parts.com/18000034.html
PostPosted: November 19th, 2011, 15:34
Hi,other new member here.
But,6Y120Pxxxx?
HDD isn't recognized in bios.
PCB may be bad,or FW?
If PCB any sugestions.
PostPosted: November 19th, 2011, 18:50
See my analysis of the PCB:
http://forums.seagate.com/t5/Barracuda- ... d-p/118542
Test points:
http://forums.seagate.com/stx/attachmen ... p_test.JPG
Hi-res scans of both sides of PCB:
http://www.users.on.net/~fzabkar/HDD/Di ... B_comp.JPG (2.1MB)
http://www.users.on.net/~fzabkar/HDD/Di ... GB_bot.JPG (1.6MB)
PostPosted: November 20th, 2011, 3:57
But,6Y120Pxxxx?
if spin up and doesn't click , check with MHDD , if stay busy forever or id differently than MAXTOR 6P120... your drive is failing and it's game over for DIY. Same if SCAN hangs or you get only X or ! in case it is identified.
PCB is not the problem.
 Post subject: Re: Maxtor HD Won't Spin Up: " UPDATE"
PostPosted: November 21st, 2011, 19:24
Installed the replacement PCB. It worked. Retrieved all my data.
Randy
Users browsing this forum: Google [Bot] and 186 guests
