 Post subject: Change Firmware Seagate Chetah SAS 300GB 15K5
PostPosted: September 29th, 2011, 2:27
I am new in this forum and working with disk as well. My problem is the next:
I have a Powervault MD3000i with 11 disk Seagate Chetah SAS 300GB 15K, especifically ST3300655SS
I was trying to change one disk which is faulty for one Seagate Chetahh SAS 300DG 15K5 Serial: ST3300657SS. The probblem is I bought this disk directly from Seagate but I cannot Update the DELL firmware for this disk. I have trying using the software give by DELL but it does not work. The Firmware from Seagate is the 008 and I would like to change it with the DELL firmaware S528 but is not succesfull.
I appreciate if somebody has done before and can explain me how to do it.
 Post subject: Re: Change Firmware Seagate Chetah SAS 300GB 15K5
PostPosted: January 10th, 2012, 17:32
I have a similar situation. Were you ever able to get the drive flashed with the Dell firmware? If so how?
Thanks,
Chris
PostPosted: November 5th, 2012, 19:05
I'm more or less at the same situation. Any updates on this?
Thanks,
Daniel
PostPosted: November 5th, 2012, 22:06
This appears to be a similar problem, but in reverse:
http://forums.seagate.com/t5/Savvio-Che ... d-p/142399
PostPosted: November 6th, 2012, 5:38
Seagate Enterprise drives have a FW lock on them. You cannot easily change from OEM to OEM
PostPosted: November 7th, 2012, 1:24
Sorry, my memory failed me. I thought the above thread was about upgrading HP firmware to Seagate retail firmware. Instead it describes how to apply a retail firmware update to a retail Seagate SAS HDD by using the firmware updater utility in an OEM update package (HP).
PostPosted: November 7th, 2012, 15:38
Then they wonder why after some time something wonderful happens.... :lol:
Users browsing this forum: Google [Bot] and 78 guests
