 Post subject: Stm3320620a fw3.aae stays busy
PostPosted: November 22nd, 2011, 8:25
Hi hi got this drive that does one click and stays busy.
i thought it was the pcb but patient pcb works on donor drive,
the terminal says
Reset
4096k x 32 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
HM SFI
ERR Read App Code
F>R
Code - A6 Track 15B83.0.238 Sns FFF
F>j
ERR App Code incompatible SFL code
F>
i did a heads swap but the drive behave same way.
and the patient heads works on the donor.
i can access the drive only in safe mode.
1 has anyone got same issue?
2 has anyone got a rom for this model and fw?
3 has anyone got a app code .ldr for this model and fw?
Thanks in advance
 Post subject: Re: Stm3320620a fw3.aae stays busy
PostPosted: November 22nd, 2011, 12:18
F>
This terminal output was made on the HDD with native PCB and before Heads were changed??
PostPosted: November 22nd, 2011, 18:37
To me, someone has badly played with FW... Or there are problems with SA.
PostPosted: November 23rd, 2011, 1:48
Pcb is not orignal my friend .
PostPosted: November 23rd, 2011, 5:43
I Agree
PostPosted: November 23rd, 2011, 5:45
When I said PLAYED WITH FW can mean they have played with ROM too. Maybe PCB IS "native" but who knows what has been stuffed into.... :mrgreen:
PostPosted: November 23rd, 2011, 10:43
hi Thank you all for your answers, the pcb is original, at least is what i have been told from the customer. My first diagnose was PCB as well but the customer told me that it didn't change it, apparently the hdd had a problem when he tried to attach it to the usb charge supply. I don't have donor for pcb that matchs exactly i used a pcb from a st3320820a with same firmware, they are sligtly different but the patient pcb works on the donor.
has anyone got the a donor ROM for this model and FW that i can write on my client pcb?
thanks again for your support
PostPosted: November 23rd, 2011, 11:24
Secondo me la ROM non c'entra un beatissimo .... niente :lol:
O non riesce a leggere parte della SA per problema fisico, o e' stato registrato qualcosa che non era il suo FW.
Prima di arrivare a conclusioni , controlla la leggibilita' dei moduli intesi come tali o come track, e verifica anche se possibile che corrispondano. Niente di strano che il FW possa anche essere stato o danneggiato o sovrascritto ;)
To me ROM is not the problem.
Either it is impossible to read SA due to physical reason or a non suitable FW was uploaded to the drive.
Before assuming anything, check readability of modules "as is" and as a track, and check also correspondence (version).
No wonder FW can be damaged or has been overwritten ;)
PostPosted: November 23rd, 2011, 13:10
Grazie blackST posso accedere ai moduli track reading, per verificare che corrispondano devo confrontare l'hex con quelli di un hdd simile?
thanks BlackST i can access to the modules using read track, how can i verify their correspondence, shall i compare the hex with a similar hdd?
thanks
PostPosted: November 23rd, 2011, 13:39
mi correggo non posso accedere a tutti i moduli! probabilmente la SA è danneggiata. Cmq riprovo e ti faccio sapere.
I was mistaken, i can't access to all the modules, maybe the SA is damaged. Anyway i'll test it again and update you
Grazie-Thanks
PostPosted: November 24th, 2011, 5:52
Ciao BlackST ho riprovato ed è possibile leggere solo alcuni moduli tra cui app code .chs credo che ci siano settori danneggiati nella SA o forse alcuni moduli sono stati eliminati o cancellati, secondo te c'è modo di accedere all'app code? sfortunatamente credo di sapere già la risposta, ma per colpa di Pandora mi aggrappo alla speranza! :)
grazie
Hi BlackST I tried again and it is possible to read few modules, one of those is app code.chs i believe there are some bad sectors in the SA or probabli some of theem have just been deleted, do you think is there anyway to access the APP Code? Unlukily i think i know already the the answer but let's hope!
thanks
PostPosted: November 24th, 2011, 9:23
Scusa un po' che tool stai usando ?
What tool/platform is being used ?
PostPosted: November 24th, 2011, 10:29
udma DE
PostPosted: November 24th, 2011, 17:02
Ci riesci a postare quello che riesci a salvare di tutta la service area, possibilmente modulo per modulo piu' la ROM oppure al limite come tracce ? (un file compresso!)
Please, post what you can save of SA possibly split into modules AND ROM, or tracks (one compressed file !)
PostPosted: November 25th, 2011, 4:30
ok dammi un oretta, grazie
ok give me some time
thanks
PostPosted: November 25th, 2011, 6:29
Ecco questo è tutto quello che son riuscito a recuperare dalla SA + il rom
here it is what i can get from SA + rom
grazie ancora
Many tanks
AA0097.zip [633.68 KiB]
Downloaded 456 times
PostPosted: November 25th, 2011, 7:36
Come pensavo.
Hai gia' fatto un tentivo con un loader per vedere se cosi' riesci a farlo almeno partire in qualche modo ?
Did you try with a loader at least to make it start somehow ?
PostPosted: November 25th, 2011, 7:56
si ho provato ma non avevo un loader dello stesso modello ho usato il loader di un ST3320820a con lo stesso fw.
Credi non sia compatibile?
yes i tried but it didn't match the hdd model i used a ldv of st3320820 with the same FW
do you thing is compatible?
Grazie
PostPosted: November 25th, 2011, 8:16
Serve il suo e anche la ROM deve coincidere.
Need his matching loader and ROM must coincide.
PostPosted: November 25th, 2011, 8:23
ok grazie, provo a cercaro su questo forum se non trovo niente cercherò un donatore. Sei stato gentilissimo grazie ancora.
ok Thanks, i'll look for it in hddguru forum if i dont find anything i'll look for a donor. Thanks for you support and kindness
Users browsing this forum: SWM and 94 guests
