 Post subject: Toshiba MK3265GSX Problem
PostPosted: November 25th, 2011, 12:49
Hi people,
I have this HDD Toshiba MK3265GSX that have been with the heads damaged.
I changed the heads, and now the drive read the initial parameters and i can save de CP modules in PC3000, but i don't have acess to the sectors.
I select the family manualy into the utility 59GSX (because PC3000 doesn't have the last one) and i got the following log:
ATTENTION!
HDD Is currently locked.
You may use command "Work with service area" / "Password removal" to unlock the HDD.
Techno On............................... : Ok
Zone table.............................. : Ok
Cyl num................................. : 169 047
Head num................................ : 2
Vendor.................................. : TOSHIBA
Model................................... : MK6465GSX
Microcode............................... : GJ003M5
G-List reading error.................... : G-List read error; Device Error Detected 51/19 (AMN;<bit3>;INF)
CP Avalable............................. : 33,34,44,56,91,92,93,94,95,97,98,9A,9B,9C,A2,A5,A6,A7,A8,A9,AA,AB,AE,AF,B1,B3,B5,B6,B7,B8,B9,BA,BB,BD,BE,C1,C3,C4,C5,C6,C7,C8,C9,CA,CB,CC,CD,CE,CF,D0,D1,D2,DD
Password removal
HDD is unavalabled, doesn`t support password, set in Frozen or Locked Mode (TON;(bit3);(bit5);BBK) 51 / AA
Executing Standby command
Ok
However i reset the password but when i go out, turn off/on i got the same log.
Does any one knows why this happens?
Thanks for your atention and time.
Regards,
Data Recovery Technician - If Data is important don't DIY without knowing the real problem.
