 Post subject: Help: Maxtor 2B020H1 110632 K,M,B,A
PostPosted: November 28th, 2011, 4:13
After loading a LDR file the SA structure test gives the below results:
SA structure test
Selected family ........................... Athena DSP
Model ..................................... Maxtor ATHENA
Firmware .................................. WAH21PB0
Serial ....................................
Min. cylinder ............................. 0
Max. cylinder ............................. 65535
Checking UList
Id ........................................ 37
Read ...................................... Yes
Header .................................... U_LIST00
Checksum .................................. Ok
The number of SA defects .................. No
P-List size ............................... 1
HDD configuration module
Id ........................................ 1F
Header .................................... ROM
Checksum .................................. Error
Serial number .............................
Max LBA ................................... 40021444
Head number ............................... 1
Head map .................................. 3
SA head map ............................... 3
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV60u
Checking User data adaptives
Header .................................... CRFTšp
Checking Zone Table
# : Start Cyl: End Cyl: SPT
1 : 214: 255: 528
2 : 256: 3476: 946
3 : 3477: 7128: 938
4 : 7129: 10604: 924
5 : 10605: 14796: 902
6 : 14797: 20349: 880
7 : 20350: 24346: 844
8 : 24347: 27777: 821
9 : 27778: 32005: 792
10 : 32006: 35452: 762
11 : 35453: 37026: 748
12 : 37027: 39524: 726
13 : 39525: 42139: 704
14 : 42140: 44291: 668
15 : 44292: 46268: 645
16 : 46269: 48843: 616
17 : 48844: 49801: 598
Checking ROM Copy
Check sum Value ........................... 62E1
Checking ATA overlays
Header1 ................................... MO
Header2 ................................... P000
OverlayId ................................. 0003
ROM CRC ................................... Ok
OverlayId ................................. 0004
OverlayId ................................. 0005
OverlayId ................................. 0006
OverlayId ................................. 0007
Checking Techno mode overlays
Header2 ................................... P0D.
OverlayId ................................. 0008
OverlayId ................................. 0009
OverlayId ................................. 000A
OverlayId ................................. 000B
OverlayId ................................. 000C
OverlayId ................................. 000D
OverlayId ................................. 000E
OverlayId ................................. 000F
OverlayId ................................. 0010
OverlayId ................................. 0011
OverlayId ................................. 0012
OverlayId ................................. 0013
OverlayId ................................. 0014
OverlayId ................................. 0015
OverlayId ................................. 0016
OverlayId ................................. 0017
Header2 ................................... ....
OverlayId ................................. 0000
ROM CRC ................................... Error
OverlayId ................................. 0019
OverlayId ................................. 001A
Checking RZTbl
Checking P-List
Checking G-List
Error ..................................... UBA 484 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 214/3/486
Checking RZTbl-PList
Difference ................................ not found
Checking RZTbl-HList
Checking HLists
Block0
Header .................................... UHRS0000
Defect Count .............................. 400
Block1
Header .................................... UHRS0010
Defect Count .............................. 91
Checking security
Error ..................................... UBA 366 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 214/3/368
Checking S.M.A.R.T.
[SMRT_T] .................................. Error
[SMRT_A] .................................. Error
[SMRT_AC] ................................. Error
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking [DISK/PW]
not found
Checking All
Module 00 ................................. Ok
Module 01 ................................. Ok
Module 03 ................................. Ok
Module 04 ................................. Ok
Module 05 ................................. Ok
Module 08 ................................. Ok
Module 09 ................................. Ok
Module 0A ................................. Ok
Module 0B ................................. Ok
Module 0C ................................. Ok
Module 0D ................................. Ok
Module 0E ................................. Ok
Module 0F ................................. Ok
Module 10 ................................. Ok
Module 11 ................................. Ok
Module 12 ................................. Ok
Module 13 ................................. Ok
Module 14 ................................. Ok
Module 16 ................................. Ok
Module 18 ................................. Ok
Module 19 ................................. Ok
Module 1A ................................. UBA 366 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 214/3/368
Module 1B ................................. UBA 484 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 214/3/486
Module 1C ................................. UBA 386 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 214/3/388
Module 1D ................................. Ok
Module 1E ................................. Ok
Module 1F ................................. Ok
Module 20 ................................. Ok
Module 21 ................................. Ok
Module 22 ................................. Ok
Module 24 ................................. Ok
Module 27 ................................. Ok
Module 28 ................................. Ok
Module 29 ................................. Ok
Module 2A ................................. Ok
Module 2B ................................. Ok
Module 2D ................................. Ok
Module 2F ................................. UBA 367 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 214/3/368
Module 30 ................................. UBA 368 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 214/3/368
Module 32 ................................. Ok
Module 33 ................................. Ok
Module 34 ................................. UBA 388 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 214/3/388
Module 37 ................................. Ok
Module 38 ................................. Ok
Module 39 ................................. Ok
Module 41 ................................. UBA 370 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 214/3/370
Module 42 ................................. Ok
Module 43 ................................. Ok
Module 44 ................................. Ok
Module 45 ................................. UBA 375 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 214/3/375
Module 46 ................................. Ok
Module 47 ................................. Ok
Module 48 ................................. Ok
Module 49 ................................. Ok
Module 4A ................................. Ok
Module 4B ................................. Ok
Module 4C ................................. Ok
Module 4D ................................. Ok
Module 4E ................................. Ok
Module 4F ................................. Ok
Module 54 ................................. Ok
Module 55 ................................. Ok
Module 56 ................................. Ok
Module 57 ................................. Ok
Module 58 ................................. Ok
Module 59 ................................. Ok
Module 5A ................................. Ok
Module 5B ................................. Ok
Module 5C ................................. Ok
Module 5D ................................. Ok
Module 5E ................................. UBA 518 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 214/3/518
Module 5F ................................. Ok
Module 60 ................................. Ok
Module 61 ................................. Ok
Module 62 ................................. Ok
Module 63 ................................. UBA 369 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 214/3/369
Module 64 ................................. Ok
Module 65 ................................. Ok
Module 66 ................................. Ok
Module 67 ................................. UBA 516 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 214/3/518
Module 68 ................................. Ok
Module 69 ................................. Ok
Module 6A ................................. Ok
Module 6B ................................. Ok
Module 6C ................................. Ok
Module 6D ................................. Ok
Module 6E ................................. Ok
Module 6F ................................. Ok
Module 70 ................................. Ok
Module 71 ................................. Ok
Module 72 ................................. Ok
Module 73 ................................. Ok
Module 74 ................................. Ok
Module 75 ................................. Ok
Module 76 ................................. Ok
Module 77 ................................. Ok
Module 78 ................................. Ok
Module 79 ................................. Ok
Module 7A ................................. Ok
Module 7B ................................. Ok
Module 7C ................................. Ok
Module 7D ................................. Ok
Module 7E ................................. Ok
Module 7F ................................. Ok
Module 80 ................................. Ok
Module 81 ................................. Ok
Module 82 ................................. Ok
Module 83 ................................. Ok
Module 84 ................................. Ok
Module 85 ................................. Ok
Module 86 ................................. Ok
Module 87 ................................. Ok
Module 88 ................................. Ok
Module 89 ................................. Ok
Module 8A ................................. Ok
Module 8B ................................. Ok
Module 8E ................................. Ok
Module 8F ................................. Ok
Module 92 ................................. Ok
Module 94 ................................. Ok
Grateful for some help.
Edsel
 Post subject: Re: Help: Maxtor 2B020H1 110632 K,M,B,A
PostPosted: November 28th, 2011, 4:43
You have all the answers...
PostPosted: November 28th, 2011, 4:48
How to proceed?
Edsel
PostPosted: November 28th, 2011, 5:10
I miss these....
Users browsing this forum: Google [Bot], SWM and 81 guests
