 Post subject: Toshiba drive label information and meaning
PostPosted: November 30th, 2011, 12:39
Greetings,
I am looking for a hard drive with the following information on the label (keep reading, there's more to it):
MK7559GSXP
HDD2J51 Z SL01 B
I always like to match every number and letter on Toshibas simply because I don't know the significance of the different characters. The trouble is that I can't find any perfect match for this drive. With other manufacturers, the date and firmware and manufacturing site, stuff like that are all clearly marked, so I know what is important. On Toshibas, though, there is no breakdown as to what means what. I was looking to see if anyone knew what the different letter groupings meant so that I could make a better informed decision of what donor to get. For example, should I get a drive with a 'ZL01' instead of 'SL01' or would a drive with an 'A' instead of 'Z' as the first standalone letter be a closer match?
Thanks for any insight you can give.
 Post subject: Re: Toshiba drive label information and meaning
PostPosted: November 30th, 2011, 17:07
What are you planning to do with the donor?
PostPosted: November 30th, 2011, 17:43
Head swap. That usually means matching country and date with other manufacturers.
PostPosted: November 30th, 2011, 17:55
You have PM
Users browsing this forum: Google [Bot], Rendersmith and 82 guests
