 Post subject: sr3500310na ns04 FW Issue
PostPosted: December 13th, 2011, 16:46
hi all, i got the barracuda in the object, it is an OEM drive and i can't access the terminal simply shorting the PCB. It seems to me the only solution is to update the FW to sn06 through standard sata connection and then try the terminal fix. I was wondering if anyone of you has done it before and if there is any save way to Updating through sata the FW.
Pls if you have done it already confirm that:
-I have to isolate the PCB to let the drive to be reconized from the updating software.
-Perform the update after i attach the pcb to the drive
-then run the solution trhough terminal
Thanks to all
 Post subject: Re: sr3500310na ns04 FW Issue
PostPosted: December 13th, 2011, 17:19
To run the firmware update the drive must detect .
PostPosted: December 14th, 2011, 5:28
shouldn't it be reconized if I connect only the pcb(then before the update attach the pcb to the drive) or if i short it during drive inizializzation?
PostPosted: December 14th, 2011, 5:29
thanks for the answer rameez
PostPosted: December 14th, 2011, 10:34
well it seems that seagate firmware update is fake, the link doesn't contain any flash.bat file! anyway you are right rameez as the pcb shows Model: ST_M13FQBL, Serial: XXXXX Firmware: 0414F34C so probably the update isn't going to work. I tryed to shot again i lost about 1 hour but still...
I can reach readness but all the terminal comands are blocked! no console available, has anyone solved the issue!?
thanks
PostPosted: December 14th, 2011, 15:28
What link?
PostPosted: December 14th, 2011, 16:49
Firmware is on the platters so the disk have to be ready in order to update new firmware .
PostPosted: December 14th, 2011, 17:28
@fzabkar http://seagate.custkb.com/seagate/crm/s ... cId=207963
@rameez i tried everything and still cant access the terminal, to try the update was a solution for Hp fw fix readed in a forum(cant tell what forum but i can pm you if you want), I tested the usb terminal on different drive and it works and i tried a solution used for drives with hp fw suggested from a dear friend that works for DR company as well, but still not luck! the prob is that the terminal doesn't seem to comunicate at all, i got ABR errors after i short the PCB and/or if i send any comand trought terminal. i really don't have any idea what it can be. The drive is an oem distribution but is it possible that seagate blocked the terminal command on it on it???:(
Even if i don't have any prove don't think is a corrupted rom as i can hear the heads initialize.
if anyone got an idea i'll gladly try it
thanks rameez and fzabkar
PostPosted: December 14th, 2011, 17:39
i dont c anything for sr3500310na at that url
" ST_M13FQBL "
Ciao, il firmware non viene letto dal tuo disco, la scritta che mi riporti è un factory alias. il seriale e il modello che vedi vengono riportati dalla ROM sul tuo terminale, ma dopo di che il disco non risponde ai comandi.
che cosa usi per la diagnostica?
Hi, the fw is not read from ur drive, the text is a factory alias.
serial and model that u see are reported from the ROM on your terminal, later on the drive do not answer to comand in terminal.What software u use for diagnostic?
PostPosted: December 15th, 2011, 4:34
Ciao uso UDMA di Ace lab, si il problema è appunto che non riesco ad accedere alla console asci di diagnosi per effettuare il fix del fw,so che per questa architettura (f3) la pcb di solito invia il modello e seriale giusto, ma sembra che per questa serie e il rom da come outpit l'alias " ST_M13FQBL " si comporta come i WD.
Comunque sono sicuro al 99% che il problema è il FW.
Hi, i use DE UDMA Acelab, yes the problem is that i can't access the terminal asci used for diagnose or fix i know that pcb from f3 architecture does usually send serial and model, even if this family behave as a WD as the model doesn't match the real one.
Anyway i do believe the problem is the FW
grazie
thanks
PostPosted: December 15th, 2011, 4:37
@fzabkar http://www.seagate.com/staticfiles/supp ... DMoose.iso
the linke states new FW SN06 but when you download it hasn't got any flash.bat
it doesn't matter anyway as i don't think anymore it would help me to solve my case.
thanks
PostPosted: December 15th, 2011, 5:59
thanks
It's ISO file, you need to burn it on a cd or other medium, then reboot and start the computer from that media.
http://www.rescue-it.se
PostPosted: December 15th, 2011, 6:25
i did burn it and it doesnt boot, also i used isobuster to check the contain and it doesn't have any flash.bat
PostPosted: December 15th, 2011, 15:52
Extract the BootImage.img file. That's a 1.44MB floppy diskette image.
Now use WinImage to open the IMG file. You will see a ZIP file. The ZIP contains your flash.bat.
PostPosted: December 16th, 2011, 5:02
thanks fzabkar, i'll try as soon as i can, do you think is worth try the update if the program allows that?
PostPosted: December 16th, 2011, 5:05
You need to recover data or to refurbish drive ?
if first one i wound't risk.
PostPosted: December 16th, 2011, 5:46
yeah i agree with you. I'll find another way.
thanks
PostPosted: December 16th, 2011, 16:07
No, I believe it would be pointless to try. I was merely addressing your question regarding the file contents of the downloaded ISO.
Users browsing this forum: Google [Bot] and 70 guests
