 Post subject: Seagate Momentus 5400.6 (st9250315as) ATA password
PostPosted: December 16th, 2011, 10:27
I have a Seagate hdd with ata password lock.
The master password revision code is FFFEh.
I try with SeDiv but momentus 5400.6 is not supported.
I'm looking for SA and SPT (right?) parameters for SeDiv or a list of terminal commands (RS-232 to HDD interface is working...) or another solution to remove ATA password lock..
Bye!
 Post subject: Re: Seagate Momentus 5400.6 (st9250315as) ATA password
PostPosted: December 19th, 2011, 2:13
There is a update version of SeDiv?
I have found SeDiv 1.0.1.4 and SeDiv 2.0.1.0 but Momentus 5400.6 is not supported...
Anyone have SA and SPT parameters for a manualy setting? Or an update of mdb database of HDD?
Bye!
PostPosted: December 25th, 2011, 15:21
Cнимается очень просто ATA командами
Security Set Password F1h
Security Unlock F2h
Security Erase Prepare F3h
Security Erase Unit F4h
Security Freeze Lock F5h
Security Disable Password F6h
Цепляться к винту по rs-232 интерфейсу
ctr+z
F3 T/
вводим /3
3/ вводим F2
дожижаемся F3 T
передергиваем питание
если надо перезапускаем hyperterminal(я пользуюсь putty)
ctr+z
F3 T/
вводим /3
3/ вводим F3
дожижаемся F3 T
ctr+z
F3 T/
вводим /3
3/ вводим F6
дожижаемся F3 T
PostPosted: December 25th, 2011, 16:45
3/ вводим F2
3/ вводим F6
:mrgreen: Redkosnaya brediatina. :good:
PostPosted: December 26th, 2011, 5:25
Hi
Can someone translate this post ,which could be helpful for everyone else.
PostPosted: January 2nd, 2012, 5:45
TaskManager wrote:
Hi
I can ask to my ucranian friend.. But the next week..
Bye!
PostPosted: January 2nd, 2012, 7:14
v3rcingetorige wrote:
TaskManager wrote:
Hi
Bye!
With Google translator:
Cnimaetsya very simple ATA commands
Security Unlock F2h
Cling to the screw on the rs-232 interface
ctr z
F3 T /
introduce / 3
3 / F2 enter
dozhizhaemsya F3 T
cringe food
if you need to restart the hyperterminal (I use putty)
ctr z
F3 T /
introduce / 3
3 / F3, enter
dozhizhaemsya F3 T
cringe food
ctr z
F3 T /
introduce / 3
3 / enter F6
dozhizhaemsya F3 T
cringe food
I start Hyperterminal
CTRL + z
/3 ENTER (go to mode 3 from T)
F2 ENTER
I received a lot of "Strange" characters..:
Current R/W User LBA 00000000 LLL CHS 000000.0.0000 PLP CHS 000000.0.0000
R/W Status 1 R/W Error 00000080 Ready
[[[G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G
€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G
€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€G€GßšGѱGíÄG©ÓG
ßGoéGÃïC?õC˜øCîúCJüC¶ýCLýCrüC°ûCûC4üCEüChûCoúCþùC8úC5úCÂúCLûCŽûC¸ûü|üü¯úg
ú®úÃú-û”ü[ý|üüùûeütü›ýPýpý§ü§üìüÆýwþqþ$þCþÜýZþ¬ýÍýÈý
`þÛþÎþ«þ+þ•þlþñþÿBÿ
ÿÿüþªþÈþÿëþSÿ‹ÿ÷ÿúÿåÿŽÿOÿÿMÿFÿªÿ‘ÿºÿ{ÿšÿ¦ÿëÿV”w ßÿ«ÿ®ÿ£
ÿßÿñÿÁÿ…ÿÃÿ‘ÿÕÿÏÿÞÿéÿ;­ÿÅÿ—ÿÊÿîÿ5
CTRL + z
/3
F3
CTRL + z
/3
F6 ENTER
Invalid Diag Cmd Parameter
Bye!!
PostPosted: January 2nd, 2012, 9:14
...just a moment... From Transcend 2.5” Solid State Disk data sheet
SECURITY DISABLE PASSWORD (F6h)
Disables any previously set user password and cancels the lock. The host transfers 512 bytes of data, as shown in the
following table, to the drive. The transferred data contains a user or master password, which the drive compares with the
saved password. If they match, the drive cancels the lock. The master password is still saved. It is re-enabled by issuing
the SECURITY SET PASSWORD command to re-set a user password.
SECURITY ERASE PREPARE (F3h)
This command shall be issued immediately before the Security Erase Unit command to enable erasing and unlocking.
This command prevents accidental loss of data on the drive.
SECURITY ERASE UNIT (F4h)
The host uses this command to transfer 512 bytes of data, as shown in the following table, to the drive. The transferred
data contains a user or master password, which the drive compares with the saved password. If they match, the drive
deletes user data, disables the user password, and cancels the lock. The master password is still saved. It is re-enabled
by issuing the SECURITY SET PASSWORD command to re-set a user password.
SECURITY FREEZE LOCK (F5h)
Causes the drive to enter Frozen mode. Once this command has been executed, the following commands to update a lock
result in the Aborted Command error:
• SECURITY SET PASSWORD
• SECURITY UNLOCK
• SECURITY DISABLE PASSWORD
• SECURITY ERASE PREPARE
• SECURITY ERASE UNIT
The drive exits from Frozen mode upon a power-off or hard reset. If the SECURITY FREEZE LOCK command is issued
when the drive is placed in Frozen mode, the drive executes the command, staying in Frozen mode.
SECURITY SET PASSWORD (F1h)
This command set user password or master password. The host outputs sector data with PIO data-out protocol to indicate
the information defined in the following table.
WORD Content
0 Bit 0 Identifier 0=set user password 1=set master password
Bits 1-7 Reserved
Bit 8 Security level 0=High 1=Maximum
Bits 9-15 Reserved
1-16 Password (32 bytes)
17-255 Reserved
SECURITY UNLOCK (F2h)
This command disable LOCKED MODE of the device. This command transfers 512 bytes of data from the host with PIO
data-out protocol. The following table defines the content of this information.
WORD Content
0 Bit 0 Identifier 0=compare user password 1=compare master password
Bits 1-15 Reserved
17-255 Reserved
How can i "Read" word from PIO data-out protocol ???
Bye!
PostPosted: January 4th, 2012, 6:38
The post of mobyx is "only" a copy from another forum.. (Posterd from arhimed15...if you search...)
Bye..
PostPosted: January 4th, 2012, 7:27
I found this information...
"Important Note: If you are trying to unlock the drive, which was blocked by the laptop, then please note that the laptops change passwords Master-automatically.
Also, the password is entered from the keyboard laptop is different from the password that is sent to a laptop drive."
My HDD was locked on a eeepc 1005ha... :(
Any idea?
Bye!
Users browsing this forum: Google [Bot], huangmiaofang, we3fan and 144 guests
