 Post subject: (this drive is protected by bitlocker drive encryption)
PostPosted: January 3rd, 2012, 5:42
a 4gb memory card is locked (this drive is protected by bitlocker drive encryption)
forgot the password pl help me how to recover the data i tried nearly with all recovery software
there is no use pl help how to recover
 Post subject: Re: (this drive is protected by bitlocker drive encryption)
PostPosted: January 3rd, 2012, 6:48
I don't think you have much chances.
That's precisely the reason that people uses encryption, so after loosing the key no one can recover it.
PostPosted: January 3rd, 2012, 6:52
there is no solution for such case with out the key.
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: January 3rd, 2012, 7:04
Double posting wont help
data-recovery-and-repair-t21588.html
As mentioned their is no way to bypass it or crack it instantly. The only way you can crack it is with a brute force attack which is what I posted in the original posting using software like Passware Kit Forensics.
Can you remember password length, if it has upper case, lower case, special case or mixed letters?
Realistically your chances are slim (even with the software) due to the time it can take to brute force the password.
Loki
PostPosted: January 3rd, 2012, 9:19
the idea of encryption is security. If you lose the key and there is a possibility to 'break' it then it wouldn't be very secure in the first place.
Probably more than 80% of encryption related cases I see are a result of a user error...
PostPosted: January 3rd, 2012, 9:51
I agree but Passware kit can recovery it quickly if it has been mounted automatically by taking a memory dump & then recovers it from that.
If the drive has not been mounted then a brute force attack can be done see
http://www.lostpassword.com/hdd-decryption.htm
Loki
PostPosted: January 3rd, 2012, 10:51
If i'm not mistaken, doesn't bitlocker create a security key somewhere in case someone messes things up with password?
PostPosted: January 3rd, 2012, 10:52
As far as I remember you get prompted to insert a USB stick for the key?
Never used Bitlocker myself for security, decrypting with the key is pretty simple so I have never worked much with cases where key is lost.
PostPosted: January 3rd, 2012, 11:10
If you bitlocker encryption on the system disk & you dont have a TPM chip on the motherboard then you have to use a usb drive which you have to plug in on boot up.
But any external drive you encrypt with bitlocker you get asked to save a key file which I'm guessing they have lost or deleted.
Loki
PostPosted: January 3rd, 2012, 20:41
Or it's just stolen
Users browsing this forum: Google [Bot], huangmiaofang, we3fan and 141 guests
