Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: WD3200BUDT
PostPosted: December 16th, 2011, 18:19
Hi all.
How to make this drive working?
50 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY        AMNF T0NF ABRT IDNF UNCR BBK 00
[WDC WD3200BUDT-62DPZY0] [            0] [             ] [                   ]
WDC WD3200BUDT-62DPZY0  LBA:0  BIOS: 81H
SN:WD-WXM1AB0S....   FW:01.01A01   CACHE:32767KB   Size = 0MB
IMPORTANT NOTICE:  This device does not
support LBA mode. MHDD will NOT work with this device.
To see enhanced information, use command EID <SHIFT+F2>
Init drive: Done
Supports: LBA48 AAM DLMC LBA MS16 DMA (UDMA6,MWDMA2)
SMART: Enabled SelfTest: Supported ErrorLog: Supported
Size = 0MB
This 2.5" hdd is from TV tuner uses NAGRA3 coding.
 Post subject: Re: WD3200BUDT
PostPosted: December 17th, 2011, 2:51
I forgot to say. HDD is 100% working in TV tuner but they are paired. Even TV provider can't do that :lol: they are working on it. Tuner must be given back to provider but HDD is our property :) and it's useless.
HDD have modified firmware.
PostPosted: February 25th, 2014, 13:17
Anyone unlock this hdd ?
PostPosted: February 25th, 2014, 14:07
Is a bad method.
Peoples on Poland unlocking this drive without PC3k ( but I don't know how)
PostPosted: February 25th, 2014, 18:51
locarno wrote:
Is a bad method.
The drive appears to be "locked" by a DCO. HDAT2 should be able to unlock it.
You have asked for help in other threads, but your feedback has always been problematic. I'm still waiting for an answer to several questions, namely which tool did you use to read MOD 02, and why does your output consist of a corrupted version of MOD 0D plus 3 out of 4 sectors of MOD 02?
PostPosted: February 26th, 2014, 10:53
Flash is readed by ELNEC programmer (SPI). Mod02 is not from my disk. I founde'd in on polish forum.
Newest HDAT don't see drive.
PostPosted: February 26th, 2014, 12:29
Wd marvel ?
And is not end of the problem. What with disk two ? Hitachi ? From this same recorder ? HCC545032B9A300
Is locked this same. And what ? I must buy tool for HGST HDD's ?
PostPosted: February 26th, 2014, 13:15
Where I can buy sediv ?
PostPosted: February 26th, 2014, 13:48
Spildit
And what is the price of WDR and Sediv ?
PostPosted: February 26th, 2014, 14:54
What is WDR ? Western Digital Recovery ?
PostPosted: February 26th, 2014, 15:00
Spildit wrote:
Sediv Seagate + WD - $350
Sediv Hitachi - $200
If you buy the 3 of them - $500
thank you
for Russia it is quite expensive.
PostPosted: February 28th, 2014, 10:45
http://malthus.zapto.org/viewtopic.php?f=95&t=812&p=3182#p3182
http://wdmarvel.com/forum/ru/viewtopic.php?f=3&t=374&start=60
New information's
PostPosted: February 28th, 2014, 13:31
@locarno, the only useful information you have provided is your MOD 02 and your ROM dump. Were you able to retrieve any other MODs from your drive, particularly MOD 802F?
The "WD3200BUDT 02mod unlocked.BIN" which you obtained from some other forum is a bastardised concoction of MOD 0D and the first 3 of 4 sectors of MOD 02. MOD 0D is corrupt -- it appears that all the 00 bytes have been replaced with 20. Moreover, the master password has been changed to "WD3200BUDT" and the capacity has been reduced to 0 LBAs.
In the absence of more useful information, I propose to edit your own MOD 02, recalculate its checksum, and then use HDDHackr to apply an UNDO.BIN file to your drive. I propose to create this UNDO.BIN file using the MOD 0D in your ROM dump plus my edited version of your MOD 02.
Before I try this, can you provide MOD 802F? This will make the procedure much easier and much less risky.
PostPosted: February 28th, 2014, 14:04
Don't discuss here.
Let's discuss on wdmarvel forum and malthus.zapto.com
PostPosted: February 28th, 2014, 15:34
@locarno, attached is an HDDHackr UNDO.BIN file which I have created from your resource dumps. I have changed only two data records in MOD 02, namely the model number (which had been filled with ASCII spaces) and the capacity. Since you will be using HDDHackr to restore your MODs rather than modifying them, the question of compatibility should not arise.
Please ensure that there is no other WD drive that could become the target for HDDHackr.
WARNING: The attached UNDO.BIN must NOT be applied to other drives, not even the same model or firmware version (01.01A01). Doing so will very likely brick the drive. That's because MOD 02 has an internal version number "00080000" which must match the original firmware.
UNDO.zip [1015 Bytes]
Downloaded 912 times
PostPosted: February 28th, 2014, 16:00
Malthus.zapto.com is down ?
Use compatibile or enchanced for hddhackr.exe
Start from floppy ?
PostPosted: February 28th, 2014, 16:02
Oh crap.
I started HDDhacker.exe. See HDD. When I started restore UNDO.bin i get this:
Can't write firmware to drive!
DRQ Error: 0x0816
What now ?
@EDIT
I can't do anything because DRQ error
PostPosted: February 28th, 2014, 17:23
Maybe the drive's protection is preventing access to certain VSCs? IIRC, Moltke made reference to MOD 61, but I confess I don't understand what is involved.
You could try the attached MHDD script. It will attempt to read MODs 01, 02, and 802F.
As for The HDD Oracle ...
Admin announcements • Programmed maintenance of the HDD Oracle server
Due to the need of urgent upgrades/updates on the HDD Oracle Server and some maintenance on the machine hosting the HDD Oracle forum, we will be off-line for a day or two.
Thanks for the attention and we will be back on line as soon as possible.
Regards.
Posted by Spildit — Thu Feb 27, 2014 7:41 pm
MHDD_script.zip [788 Bytes]
Downloaded 1005 times
PostPosted: March 1st, 2014, 4:53
Sorry for stupid question, but how to use this script's ?
Only MHDD 4.5 support script's ?
I have diksette with mhdd4.5.
Where put your script's ?
PostPosted: March 1st, 2014, 5:48
Ok. Now I know how to do:
Result's
Users browsing this forum: No registered users and 46 guests
