 Post subject: WDC WD1502FAEX-007BA0 Bad Sectors?
PostPosted: December 17th, 2011, 8:05
Hey guys,
a friend just gave me his WDC WD1502FAEX-007BA0 1500GB.
He told me that, after some mb of data copied, the drive starts "ticking" and explorer.exe is fu****.
So I booted to MHHD32 v 4.6 and started ERASE. After 644mb I got an "Catastrophical Error".
After that I tried SCAN with Erase Delays ON but after about 5min or so it stops again and instead of blocks I only see a "w".
Could someone just tell me what might be the Problem?
 Post subject: Re: WDC WD1502FAEX-007BA0 Bad Sectors?
PostPosted: December 17th, 2011, 8:17
Internal problems (e.g. head / media problems) seem most likely, although others are possible. I see no chance for DIY recovery here, so since you don't need the data, IMHO buying a new drive is your cheapest option.
PostPosted: December 17th, 2011, 8:45
Hmm ok thats bad. Anyway thanks for your help.
PostPosted: December 17th, 2011, 9:10
You can wait to see if someone else has a different view, based on those symptoms, but I see no point in further investigation if you don't need data recovery (which would cost more than a new drive)
FYI this thread was moved, as you posted it in the wrong section (this topic is not related to new DR technology etc.). When you get a notification in your email to read an update to the thread, that will still link to the correct place.
Good luck :)
PostPosted: December 17th, 2011, 9:33
Sorry for the wrong Topic. As you can see Im new to this Board. ;)
Data Recovery isnt even necessary. Everything I need is safe. I just wanted to get the Drive back to work again.
PostPosted: December 17th, 2011, 9:46
Can't you RMA it?
PostPosted: December 18th, 2011, 3:09
Probably NO since the disk prices are almost 3x'ed. A cheaper and quicker option would be finding someone who can refurbish it PROFESSIONALLY, eventually defeating bad head or surface - this means downsize. I am a bit distant...
Users browsing this forum: Google [Bot] and 251 guests
