 Post subject: Mhdd script for Fujitsu hdd
PostPosted: December 27th, 2011, 15:45
Hi, i need to a script for unlock the hdd Fujitsu MHN2200AT, i've founded my old pc and I would like give it to my son, but I don't remember the password ATA. Who can help me, please? I'm italian so I don't understand a lot of words, I look foreward to receive your answer, thanks ;)
 Post subject: Re: Mhdd script for Fujitsu hdd
PostPosted: December 28th, 2011, 5:17
Nobody can help me? :(
PostPosted: December 28th, 2011, 7:18
:shock:
PostPosted: December 28th, 2011, 7:29
Try zu utility
PostPosted: December 28th, 2011, 12:05
No, ZU doesn't work. (Command "ZU /P" see the drive but only return "UNLOCK NOT DONE")
I need a MHDD script for reading ATA Password in Security Area for this fujitsu hdd, so that i can use the resulting file with Victoria (all in DOS native mode).
I have read another thread with this procedure (but for a Western Digital hdd).
A PM with script attachment would be very accepted :lol: :lol:
Obviously the data stored are not important.
@BlackST
Sei italiano? Pensi che mi sono espresso abbastanza bene da farmi capire?
O sto chiedendo troppo? Ciao.
PostPosted: December 28th, 2011, 12:16
http://hdd-tools.com/products/rrs/ supports your drive & the data is safe but it will cost $49.95
http://www.hddunlock.com/ support your drive but the data is wiped but it will cost $4.97 for drives uptp 40Gb
Loki
PostPosted: December 28th, 2011, 12:39
Sorry can not help you it relays on special commands and scripts and does not work in normal mode at all. You best bet is to send it to BlackST there in Italy and he can help you with this one. But nobody will give out a script in public forum to help you with this one. Sorry not possible. I am sure the price will not be much for him to do this one.
Iorana Haraharaini
PostPosted: December 28th, 2011, 12:50
ntsita wrote:
@BlackST
Forse le regole non sono molto chiare o si assume che tutti capiscano. Le cose stanno cosi' : a parte qualche "rimedio" per poche specifiche famiglie di dischi (vedi script per WD) , a meno di non usare strumenti specialistici e molto costosi, e' necessario sapere come quei dischi funzionano. OVVIAMENTE sappiamo come fare, con o senza strumenti, MA il problema e' che certe informazioni NON si possono dare per problemi legali, ed e' anche meglio NON insistere :mrgreen: 8)
Se proprio non riesci, ci sono soluzioni online a pagamento, oppure rivolgiti al professionista piu' vicino che abbia gli strumenti di cui sopra, che probabilmente ti chiedera' o una prova che il PC sia davvero tuo, oppure di firmare una lettera di scarico di responsabilità prendendo i tuoi dati. Perlomeno questa e' la regola.
Diversamente, piano B , procurati un altro disco anche usato e reinstalla il SO.
Prima del piano B io mi sforzerei di ricordare o provare tutte le password.
Sicuramente non era quello che tu (e altri) volevi sentirti dire , ma e' il caso di evitare problemi non necessari ;)
Maybe some rules are not fully understood, or the hope is that everybody understands. These are the facts : beside some "remedy" for some specific drive/family (i.e. WD), without specialized tools it is necessary to know how stuff work. Obviously we know how to do it, with or without tools, BUT some info CANNOT be posted for legal reasons, and would be better NOT re-trying to ask :mrgreen: 8)
If you don't succeed, there are online solutions (at a cost!) or you can refer to the nearest pro who has the necessary gear. You'll probably be asked for a proof of ownership of the PC or sign a responsibility agreement , giving your ID data. This is usually the rule.
Otherwise, there's PLAN B : get another disk , used or not, and reinstall OS.
Before plan B I would try to remember or guess the password.
Maybe this is what you (and other) didn't want to hear, but it's a must to avoid unnecessary troubles ;)
PostPosted: December 28th, 2011, 13:43
@BlackST
Ringrazio per la spiegazione esaustiva, ma il gioco non vale la candela.
Questo thread si può anche chiudere.
Io non ho la possibilità di mandare PM ma forse di riceverli (per qualche giorno terrò d'occhio l'Inbox)
Ciao Black (dal tuo profilo ho visto che siamo coetanei).
A big Hello to all.
This thread can be closed.
PostPosted: January 5th, 2012, 7:26
ntsita wrote:
@BlackST
A big Hello to all.
Approfitto...
Hdd seagate ata password locked.. non mi interessa recuperare i dati (ho un backup fatto con Acronis..) ma senza conoscere la password (ne user ne master..) vorrei formattarlo e rimuovere tali password..
ESISTE una soluzione? o lo caccio via?
Bye!
PostPosted: January 5th, 2012, 10:03
Esiste.
PostPosted: January 5th, 2012, 11:36
BlackST wrote:
Esiste.
PostPosted: January 9th, 2012, 17:17
v3rcingetorige wrote:
BlackST wrote:
Esiste.
ummm.. La cosa comincia a diventare interessante..
Affiniamo il tiro.. con vari PC3000 ecc, si fara' sicuramente..
Ma armati solo di un convertitore RS232-LVTTL, posso "OSARE" qualche manovra o non ho speranze?
With only a RS232-LVTTL, can i try to unlock the hdd? (or is impossible without a PC3000...)
Bye!
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 168 guests
