 Post subject: HDD ST3500820AS in IOMEGA case
PostPosted: December 29th, 2011, 8:34
Hello.
I have two hard disk SEAGATE in IOMEGA case with the same problem. The motor sinup but does not recognize.
ST3500825AS
F/W: SD25
Is it possible to be a busy problem as hhds with f/w sd15?
Thank you
 Post subject: Re: HDD ST3500820AS in IOMEGA case
PostPosted: December 29th, 2011, 8:39
Hi, First of all, take the drives out of the enclosure and connect them directly to the motherbord, then tell us how it looks.
Bosse
http://www.rescue-it.se
PostPosted: December 29th, 2011, 8:56
Can you connect terminal to it and check it's log?
PostPosted: December 29th, 2011, 10:20
You are probably better off getting the drive assessed by a pro with the right tools, if your data is worth anything to you.
Users browsing this forum: Google [Bot] and 85 guests
