 Post subject: help request with seagate 7200.12
PostPosted: March 3rd, 2012, 18:04
hello, i have a 160GB SATA ST3160318AS FIRMWARE:HP11 disk drive which does not seen in bios.
i get these terminal codes
Rst 0x08M ctrl-Z
F3 2>Z
Spin Down Complete
Elapsed Time 260.272 msecs
F3 2>U
ExecuteSpinRequest
HighPowerMode
Spin Up Complete
Elapsed Time 3.572 secs
F3 2>/1
F3 1>N1
Init SMART Fail
LED:000000CC FAddr:0024E991
i waited a while but last code repeats. what can i do, is it possible to recover data?
thank you for any helps.
 Post subject: Re: help request with seagate 7200.12
PostPosted: March 3rd, 2012, 18:19
'internet fix' ?
PostPosted: March 3rd, 2012, 18:25
can you help me? i dont want to do anything wrong.
i need some important files very urgent.
PostPosted: March 3rd, 2012, 18:38
Hi, contact member Pcimage...he can help you urgent with this drive.
http://www.rescue-it.se
PostPosted: March 3rd, 2012, 19:33
is there any terminal commands to diagnose my issue?
btw, i can not go to a disk pro. because of financial problems
and tomorrow is sunday :(
PostPosted: March 3rd, 2012, 20:33
But your already "mucking" around in the terminal so your chances of doing anything "wrong' are close to 100% a very dangerous place to "play" if you don't know the commands and what they do. The symptom looks a lot like bad heads which would not be DIY. It also could be firmware corruption again no pro tools no DIY. wish I had better news to share if you have any backups I suggest another drive and a restore
PostPosted: March 4th, 2012, 3:30
Sadly, this is a no money = no data case :(
PostPosted: March 4th, 2012, 10:35
sory to hear that from you
PostPosted: March 4th, 2012, 11:11
Have to agree with BlackST and Networks...
One wrong move and cost of recovery will triple...
PCimage will help you for very reasonable money.
www.datarecoveryne.com
PostPosted: March 11th, 2012, 9:00
hi again,
last week i send the disk to a pro (whom i previously know and recovered for a cost), and waited to hear from him for 3 days. unfortunately he said that he is unable to recover data from that disk. as he said the disc surface is unreadable. i took the disk back. see that he did not open disc. asked him what to do next, he answered to send disc to seagete, may be they can recover for a cost of approximately min. 3000-4000euros.
are you agree?
note: the disc isn't mine. and i don't know if the owner send the disc to recovery before giving to me. if so is it possible to take data from it and make it unreadable and delete?
thanks for your replies and sorry for my bad language.
PostPosted: March 11th, 2012, 9:16
Looks too high for this case I think. :roll:
PostPosted: March 11th, 2012, 11:20
I think you should hand the drive to a trusted pro who will perform accurate diagnostics (instead of "surface unreadable") and quote you for recovery.
$3000-$4000 is a bit steep in my opinion.
Contact PCImage he will diagnose drive and quote for recovery. I am almost sure the final cost will be a portion of the one mentioned.
Users browsing this forum: No registered users and 381 guests
