 Post subject: Seagate Barracuda LP ST31000520AS (1Tb)
PostPosted: January 13th, 2012, 11:57
Hi everyone,
I have that Seagate disk that does not spin anymore. I removed the PCB and saw that the two resistors at the very right side, near the power supply connector, are burnt. Details of the drive are as follow:
S/N: 9VX0670F
P/N: 9TN154-510
Firmware: CC32
Date Code: 10065
Site Code: TK
In the other hand, I have another (but working) drive: Seagate Barracuda 7200.12 ST31000528AS
S/N: 9VPAVPD8
P/N: 9SL154-303
Firmware: CC46
Date Code: 11237
Site Code: TK
As PCB's looked identical, I swapped them but I was not optimistic. Of course, I was right not to be... The drive started to spin, clicked for a few seconds and then spinned down (exactly like tgrans21's explanation).
What are the possible solutions ? Would it be possible to "bypass" those two burnt resistors ?
Many thanks in advance.
 Post subject: Re: Seagate Barracuda LP ST31000520AS (1Tb)
PostPosted: January 13th, 2012, 16:54
By luck, I have found another Seagate Barracuda LP ST31000520AS:
S/N: 5VX09TXY
P/N: 9TN154-510
Firmware: CC32
Date Code: 10064
Site Code: WU
I swapped the PCB's. The disk starts, clicks for a while (in another way), then continues spinning. But it's not detected by the BIOS.
Could I expect something with the "LBA 0" trick ? I thought it could make the drive detectable again in order to duplicate it with ddrescue.
Again, many thanks in advance for your advises.
PostPosted: January 13th, 2012, 16:56
You have to transfer ROM chip from original PCB to new one in order to make your drive work.
That chip contains unique microcode to your drive.
www.datarecoveryne.com
PostPosted: January 13th, 2012, 17:10
Harddrivespecialst is correct, all PCBs on this series are absolutely unique.
PostPosted: January 13th, 2012, 18:15
Right. The problem is that I do not want to destroy any of those two working disks. Is the soldering iron the only solution ? Is there no way to flash the drive as suggested there ? (I guess you will tell me that ROM is not EEPROM...)
Is the ROM the 8-pin chip on the top or on the left ? (On the top-right, you can see the burn area.)
Many thanks.
Users browsing this forum: No registered users and 32 guests
