 Post subject: WD 500 GB (WD5000AAKS) clicks and spins down
PostPosted: January 22nd, 2012, 2:57
He we are...a failing drive. So I have had a rough couple of weeks here. I screwed up my internal drive while partitioning (froze in the process, rebooted, file system was corrupt, ran chkdsk...etc etc etc and got a half-way decent set of files back). Of course, I backed most of it up on this 500 GB drive and now I cannot access it. I plug it into the usb port, switch the power on...and I get four "clicks", pause, another "click", silence.
Please tell me there is something I can do to get it on and running. I am using UbuntuLive now with a buddies External HDD and at the very least, I want to image the drive onto his drive and start to see some daylight here.
I am attaching a soundbyte of the noise here...N.B., it is a bit loud as I had the mic turned up high.
http://www.2shared.com/audio/BT4HxxG1/2 ... 15411.html
http://www.2shared.com/audio/Pgb0D5ex/hdd_sound.html
 Post subject: Re: WD 500 GB (WD5000AAKS) clicks and spins down
PostPosted: January 22nd, 2012, 9:12
Bad heads.
Sorry mate, this is definitely NOT DIY.
IF you care about the data, do not power up the drive anymore and consult a DR Pro.
We can recommend some good professionals from your area if you like.
PostPosted: January 22nd, 2012, 10:11
northwind wrote:
Bad heads.
Ditto
PostPosted: January 22nd, 2012, 11:04
Bummer...that is what i thought... I guess the inlybway tobfix it is to send it i a pro right?
Yeah recommendations would be great...preferably on the cheaper side...
PostPosted: January 22nd, 2012, 18:40
Be careful seeking for cheap service. If the data is important, the cheap route may not be such a good idea.
I would say educate yourself first. Search online and make some phone calls.
Users browsing this forum: No registered users and 148 guests
