Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Another WD 2TB 20EARS green issue - ABRT on all sector reads
PostPosted: January 31st, 2012, 16:30
WD 2TB 20EARS green from an external black enclosure
Standard sata drive
Spins and no obvious noises
Can get the drive passport via Victoria etc
and shows the correct drive and number of LBA's
and not locked
SMART shows 733 current pending sectors (in red)
Test read (verify or read, ignore failures) shows ABRT for all sectors
Is it a likely to be an easy fix for a professional?
(If so, I'll set yet another potential customer to some of the UK professionals on here)
 Post subject: Re: Another WD 2TB 20EARS green issue - ABRT on all sector r
PostPosted: January 31st, 2012, 16:32
I might try some WD techniques to read sectors / modules (non destructive stuff only)
just to see if those reads work
PostPosted: January 31st, 2012, 16:41
PS It a big black plastic WD external enclosure, but no model number on it
I dont think the USB to SATA adapter was doing encryption or exposing the usual WD SMartWare drive
But possibly it was
PCB says OASIS DESKTOP 1607P
But even if it was, would expect to be able to read the raw, encrypted, sectors rather than get ABRT
PostPosted: January 31st, 2012, 17:06
Do you have PC3K? If so this seems to be a problem that is getting more common on these 2TB drives and there is a work around with PC3K.
PostPosted: January 31st, 2012, 17:28
ABRT on all sectors - could be corrupt translator.
Data Recovery Cape Town
PostPosted: January 31st, 2012, 17:37
INIC-1607P is not encrypted.
See http://www.si-tech.co.jp/eng/v-ini.php
Notice that there are "P" and "E" versions of several bridge ICs. The latter are encrypted.
PostPosted: January 31st, 2012, 17:51
For info. The mhdd scripts for reading 'blocks' 21 and 22 on WD drives seem to work and return the expected contents
A simple mhdd script for reading normal user areas sectors via ata commands looks like it errored out
PostPosted: January 31st, 2012, 17:52
Also could be a drive that fails it's initialization process, we are seeing a TON of these.
PostPosted: January 31st, 2012, 18:01
This symptom can be caused by almost all of the different things that can be wrong with a hard drive :wink:
PostPosted: January 31st, 2012, 18:38
Like people are saying, this could be a lot of things.
Most common issue we are finding on these seem to be a weak/bad head(s) preventing the drive initialising the translator properly.
Requires proper diagnosis. We can do this.
As fzabkar says,this is not encrypted. But that would not affect the reading of sectors with MHDD anyway.
PostPosted: February 1st, 2012, 8:23
This is what I would begin with :)
But as mentioned, the first thing you need before attempting anything is a solid diagnostic.
PostPosted: February 1st, 2012, 10:01
I have the same drive now with the same problem and I'm going to replace the heads. It's 6 heads, and I will post the results.
PostPosted: February 1st, 2012, 12:19
didn't you read any of the above?
PostPosted: February 1st, 2012, 14:09
I have a sore throat so I'm going to perform a tonsillectomy on myself.
PostPosted: February 1st, 2012, 15:42
You might like to invest in WDR-UDMA or WD HD Pro (US$80 - $150). Otherwise I could help you read the other MODs using MHDD scripts.
That said, you should be able to read all the lower numbered MODs (00 - FF) using http://nazyura.newmail.ru/Mavr_r.zip. However, you will need to configure your SATA port for legacy IDE mode so that it occupies port address 0x1F0 or 0x170. I've just been through this with someone else ...
PostPosted: February 2nd, 2012, 3:24
Guys, "unknown" is a different user than the OP. AIUI, "unknown" is a pro who happens to have a similar case.
Or not?
PostPosted: February 2nd, 2012, 3:54
Or not?
I notice that s/he has racked up 506 posts. That usually suggests that the poster is a pro.
PostPosted: February 2nd, 2012, 9:38
I'm not a beginner guys. :)
PostPosted: February 2nd, 2012, 9:39
Or not?
Thats means I'm half way there :D
PostPosted: February 2nd, 2012, 11:09
Or not?
No it does not =) I am no pro. Hence forth i am to be called advanced amateur =) Hear ye hear ye = )
Users browsing this forum: No registered users and 60 guests
cron
