 Post subject: calibration issue on WDCMarvell hot-swap
PostPosted: February 2nd, 2012, 13:35
i am going crazy i can't understand the reason why it happens:
i have got a Mariner WDCMarvell 2,5 (WD5000BEVT-00A0RT0) with several demage in SA.
i was able to extracts by hot-swap (with a drive same model different firmware) modules for data-access and wrote that on the patient (that has got same firmware)
With that drive by Hot-swap i was able to read some sectors but when i forgot to disable hardware reset i had to re-make hot-swap procedure, but the drive can't calibrate.
So i try a hot-swap with another drive same family but different firmware, and the patient can calibrate. why?
 Post subject: Re: calibration issue on WDCMarvell hot-swap
PostPosted: February 3rd, 2012, 18:32
i finally fix this! i had to use DataCompass start/stop motor, to get the drive calibrating after smart hot swap.
Now i am cloning, the power come from salvation-data and the ATA cable goes to PC3000 (when i got calibration i detached ata cable from Data Compass and plugged to ATA-0 in PC3000) :mrgreen:
So China-Russia work together! ( a bit costly )
PostPosted: February 4th, 2012, 5:21
:shock:
Wow!!!
That's what I call being inventive.
Good job, but... a little strange, isn't it? Maybe some cable problem?
PostPosted: February 4th, 2012, 5:29
i think better way to manage stop motor of DC, since this drive has problem in calibration with head #3, and this bring pc3000 to not calibrate ( i am cloning by selective heads becouse head#3 can't almost read anything - will swap later now i am at 50% of cloning )
This drive was judged unrecoverable by an other DR, but when it arrived in my Lab i noticed that i could access to some modules of fw (mostly were demaged and shifted so i lost so many hours to reconstruct them)
PostPosted: February 4th, 2012, 7:25
Did the other company that claimed drive unrecoverable, try to change heads?
Anyway, good job my friend :good:
PostPosted: February 4th, 2012, 8:29
yes, power cable problem I think, my own pc3k sometimes has loose power connection, have to be very careful when hotswapping. New pc3k system is fine, it's just wear and tear of the power cable.
PostPosted: February 4th, 2012, 8:43
Yes they changed heads, thanx nortwind!
yes - maybe - but honestly i tryed with both ATA ports..and many times... i feel DC manage slightly different, it's only an impression.
just few hours ago, after 60% of cloning, i had to power off, and still DC allowed me ( with difficulties ) to calibrate. (PC3K not again)
By the way it's not only press "start motor" button that i solved that.. still a little fantasy and inventive ( i leave this for your imagination ) and i got again my drive ready to continue the cloning ( now i am at 70% )
What make me fun is to see both machine attached together :lol:
PostPosted: February 4th, 2012, 8:49
I have had a lot of problems with cables in the past, esp. those molex to sata adapters.
After the last incident I have decided to change cables to all machines every two months.
Users browsing this forum: No registered users and 67 guests
