 Post subject: Samsung HM160HC HotSwap Concerns
PostPosted: February 5th, 2012, 12:07
The history of the drive... CLIENT CHECKED BY SWAPPING PCB, then gave me the drive with ORIGINAL PCB.
Prob: Always BUSY, doesn't come to Ready by SoftReset.
Did Hot Swap, and found First module (FSI) to FTRS_RT2 is OK (Except 008E & REF_TMR), and REST ALL THE MODULES ARE CORRUPT After FTRS_RT2.
N.B. REF_TMR can't be read even in DONOR.
Here is the terminal log
IS=+00004
SO
Ld
ENG>SRV> SR : +00000
Ud
Ld
SvoTbl Loaded
BD
LED 5B
LED 5B
LED 5B
LED 5B
LED 5B
LED 5B
LED 5B
LED 5B
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Samsung HM160HC HotSwap Concerns
PostPosted: February 5th, 2012, 12:15
You may want to look at this thread samsung-hd501lj-starting-calibrate-then-power-off-t14131.html
Users browsing this forum: Google [Bot] and 153 guests
