 Post subject: WD10EACS doesn't power on
PostPosted: February 7th, 2012, 14:08
This ext. drive WD10EACS-00ZJB0 doesn't power on. i had a closer look at the pcb and didn't see burned chip or similar. Xronis (rafaela) saw the HDD and told me that there is propably an error with the smooth chip.
if i have to change the pcb how can i read the ROM of the drive?
any other opinions would be appreciated.
i attached a photo of the pcb
thank you
DSC00566.rar [1.99 MiB]
Downloaded 441 times
 Post subject: Re: WD10EACS doesn't power on
PostPosted: February 7th, 2012, 14:15
You will need to reprogram the new PCB with some tools like (Atola, PC3K, SD tools..etc).
PostPosted: February 7th, 2012, 15:36
You can read the ROM modules from the platters using WDR-UDMA (US$150) or WD HD Pro, and then rebuild and reprogram the ROM on your replacement PCB. AIUI, it's a single-click procedure.
If you would like to narrow down the fault, then you can measure a few voltages.
Start with Q8 near them jumper block. That's probably the +3.3V supply.
Then measure the voltages at L2, L3, D3, L5, D4. One or more will be Vcore.
PostPosted: February 9th, 2012, 4:30
i checked the pcb and the results are:
Q8 - 1,78V
L2 - 0.0V
L3 - 0.0V
L5 - 0.0V
D4 - 0,13V
as far as i know D4 show be 5V, L2,L3,L5 0,0V.
shall i intervene and make changes to the pcb?
thank you
PostPosted: February 9th, 2012, 17:05
I don't understand your measurements. For example, Q8 has 3 pins (plus a metal tab). Therefore you should measure 3 voltages, eg +3.9V, +5V, +3.3V. You should also see a Vcore voltage, probably +1.2V, at one of the inductors (Lx).
Are you measuring the voltages of your components with respect to circuit ground?
PostPosted: February 13th, 2012, 13:14
Yes i am sorry. i didn't analyse it as i should.
the measurements are:
Q6 - 1PIN - 1.77 V
- 2PIN - 0.00V
- 3PIN - 1.11V
D3 - 1.35V
D4 - 0.14V
D5 - 6.52V
L2,L3,L5 shows 0,00V
thanks for your reply
PostPosted: February 13th, 2012, 14:51
I assume you mean Q8, not Q6.
Anyway, I have re-examined your photo and I notice that resistor R82 near the SATA power connector is missing. That would explain why you don't see +5V at the middle pin of Q8.
Install a wire link in place of R82 and then you may have a chance.
PostPosted: February 13th, 2012, 15:34
Also confirm that R83 measures 0 ohms. R82 is associated with the 12V supply. Sorry.
Users browsing this forum: Google [Bot], michael chiklis and 85 guests
