 Post subject: HOW IS THE BEST WAY FOR CLEANING HEADS? DISCUSS
PostPosted: February 7th, 2012, 11:06
Hi, guys, how do you think is the best way for cleaning heads?
Discuss
 Post subject: Re: HOW IS THE BEST WAY FOR CLEANING HEADS? DISCUSS
PostPosted: February 8th, 2012, 6:09
Normally, I clean the heads using clean air, making the air flow betwen heads.
I repeat this process 2 or 3 times.
Discuss
PostPosted: February 8th, 2012, 18:00
what do you use?
Disscuss
PostPosted: February 9th, 2012, 5:03
Hot soapy water.
Discuss
PostPosted: February 9th, 2012, 5:32
Bleach and sandpaper :wink:
PostPosted: February 9th, 2012, 17:59
Wire brush and Dettol
PostPosted: February 9th, 2012, 19:13
Wet head with water
Then apply
If with hair - shampoo
If bald - shampoo or normal soap would do
rub head and rinse with water and you should have a clean head afterwards
PostPosted: February 14th, 2012, 4:35
Hi all, thanks for your clever responses.
Who uses Paper for cleannig heads with alcohol?
Who uses brus to clean at microscope?
Thaks all
PostPosted: February 15th, 2012, 11:37
heard of some ppl using alcohol on paper. Never do that myself , i just change em. Sry.
Users browsing this forum: Google [Bot], we3fan and 69 guests
