 Post subject: imac hard drive drive
PostPosted: April 11th, 2012, 10:42
I need to install a new hard drive in an Imac. The original hard drive is a Wd 500gb. I have a new WD 500gb and a new 1gb WD hard drive but neither will work in the Imac. It wont boot off cd when those hard drives are in it but if I but old one back it will boot. I found this http://forums.macrumors.com/showthread.php?t=1152046 and was wondering if there was any way around it. I dont mind the fans i can use fan control or something but i cant install OSX.
 Post subject: Re: imac hard drive drive
PostPosted: April 11th, 2012, 18:11
Given the increasing rate of heat-related failures in Mac's, it's probably a good thing.
What is the model of the old drive in your iMac?
Data Recovery Ireland
PostPosted: April 11th, 2012, 20:59
If it's a newer imac, you'll need to get a hard drive from Apple; the firmware on the drives is modified. I don't know of a way around this.
http://www.datasaversllc.com
Users browsing this forum: No registered users and 247 guests
