 Post subject: wd10tmvm-11zsms1 0MB problem
PostPosted: February 29th, 2012, 12:00
i have a WD 1T Passport (wd10tmvm-11zsms1)
during a extracting files return a error and now it show 0MB in size and i can not recover it with my recover software
any body had a same problems ?
can any body now any software that can read a 0MB partition or repair this error
because any known software can not recover this drive
 Post subject: Re: wd10tmvm-11zsms1 0MB problem
PostPosted: February 29th, 2012, 12:02
Its not a software problem. Your drive has a problem.
www.datarecoveryne.com
PostPosted: February 29th, 2012, 12:04
If the drive spinning ok then Its FW problem.
PostPosted: February 29th, 2012, 12:05
yes i know
now i am searching for a software that can read data on this drive
PostPosted: February 29th, 2012, 12:07
how can i write firmware ?
is there any software ?
PostPosted: February 29th, 2012, 12:34
Please read this, to help you to understand why disk firmware problems are not as easy as you seem to be thinking:
diy-what-the-big-deal-t12671.html
PostPosted: March 5th, 2012, 1:11
You need a tool such as the serial version of WD HD Pro, and you need to communicate with the drive via its serial console. There are Tx/Rx and Ground pins at the end of the 12-pin header.
Then you need to understand what you are doing. In particular, you need to understand what is meant by "firmware".
See newbie-info-from-and-for-newbies-about-firmware-etc-t6562-20.html
Users browsing this forum: Google [Bot] and 58 guests
