I've had this idea for a while: somehow stick together 4 jumpers so I don't have to add and remove one-at-a-time every time I need to put a drive (i.e., 3.5" WD) in safe mode. I didn't realize how easy (and supremely convenient, if you hate waisting time like me) it would be to make:
1) Find 4 jumpers of equal size (equal width is the important part, some jumpers have little "lips" on the top, which are wider than the bottom and don't line up properly when all four pushed together)
2) Hold all four together using thumb and index finger
3) Tape exposed side of all four jumpers (I used Kapton tape, just because the width was perfect)
4) This will hold all four together, now move your fingers and wrap tape around other 3 sides
5) Make a little "handle" out of tape, so it's easy to pull out
6) Using scotch tape, tape the bottom of the jumpers (this prevents the middle jumpers from staying connected to the hard drives when pulling the jumpers out)
7) Gently press "4-Jumper" into the jumper pins of a hard drive, to break through the tape on the bottom
Enjoy QUICKLY jumping your drives!
