 Post subject: RAID10 Recovery in UFS Explorer
PostPosted: March 8th, 2012, 11:25
I am trying to recover my data from raid10 (ext4 filesystem) with Ufs Explorer Standard Recovery. I have three disk images (one missing disk is damaged).
File comment: screen1
I used plugin to build virutal raid. I added ext4 partition as first and unkown partition as second.
File comment: screen2
In "raid preview" filesystem is opened but I see only one dir named "lost+founds" and it is empty...
File comment: screen3
what should I do now to recover my data?
Thanks for your time.
Kamil
 Post subject: Re: RAID10 Recovery in UFS Explorer
PostPosted: March 9th, 2012, 8:26
2 questions.
From the 3 drives, have you found out already which ones are belonging to the RAID0?
Also, are you sure about the stripe size?
PostPosted: March 9th, 2012, 9:03
All disks will have MBR because striping does not start at sector 0. This is why you see all same information.
Use Winhex to look at sector 20975619, should be Linux superblock at at least 1 disk. Other disk should have empty space (probably)
PostPosted: March 9th, 2012, 9:54
first partition is system (gentoo), second swap and data is on third and fourth partitions.
File comment: mdadm raid
it is mdadm software raid with default options (chunk-size=512)
I think sdd does not contain valid file system..
PostPosted: March 9th, 2012, 10:14
And have you compared sdb and sdd to check if the content is the same?
PostPosted: March 9th, 2012, 10:24
This should be fairly simple case. If it is giving you so much problems then let someone else handle it for you. Very likely it can be handled remotely.
PostPosted: March 9th, 2012, 10:38
Contact DR-Kiev,
He will be able to rebuild your RAID remotely for a small fee.
www.datarecoveryne.com
PostPosted: March 9th, 2012, 14:17
Where is DR-Kiev? :)
I received few private messages but I am new here so I cannot reply :(
Please contact me by email del_jachim@o2.pl
Thanks!
PostPosted: June 3rd, 2016, 3:32
too late
recovered ?
PostPosted: June 3rd, 2016, 9:04
SALIM wrote:
too late
recovered ?
Mr Salim,
This Was Posted In 2012 ,What on Earth Are You Thinking ,Concentrate on your lab and work instead of this useless posts brother .
PostPosted: June 8th, 2016, 17:09
thanks
amar bhai
Users browsing this forum: chris01479, Google [Bot], hawkinf, Majestic-12 [Bot] and 63 guests
