 Post subject: Partition recovery help?
PostPosted: March 14th, 2012, 10:53
Hi Everyone!
I've got a dilemma.
I was using a restoration command (dd) in Linux to restore a backup onto another hard drive. Mistakenly I ended up "restoring" to the source hard drive. Luckily almost no data was written but the drive was changed from a 1TB partition to the partitions of the backup source.
I am wondering what tool might be best to recover the partition I need with all those files.
Also would it make sense I need to delete all of the partitions on the drive ebcause that's all that recovery software seems to pick up right now.
 Post subject: Re: Partition recovery help?
PostPosted: March 14th, 2012, 11:16
There are plenty of tools out there.
R-Studio
Get Data Back
'Disk Internals
You do have to pay for these software packages, but I hear you can 'obtain' them from some magical websites.
PostPosted: March 14th, 2012, 11:30
The software you mention is developed by clever guys who put a lot of work into what they do. Since I use a lot of the software daily its only fair that I use them with a legit license.
You should not encourage piracy, it undermines all the hard work and time that goes into the software products that are essential in this game...
PostPosted: March 14th, 2012, 15:56
Internal hard drives have a typical data transfer rate of 100MB/s. This means that even 1 second is enough time to destroy your file system, not just your partition information. Therefore I expect that raw recovery will be your only hope.
I would suggest that you clone your corrupted drive, sector by sector, and then work on the clone. In order that your software will not be confused by the presence of a second file system, I would perform a sector-by-sector comparison of your corrupted drive against your original target drive. Note the LBA of the first difference, and then zero fill all sectors prior to this LBA.
PostPosted: March 14th, 2012, 16:48
What was the original file system, and how much data did you copy before stopping it?
PostPosted: March 14th, 2012, 21:15
First make a clone.
testdisk will do the job.
success
Users browsing this forum: Hardcore Games, Rendersmith and 85 guests
