 Post subject: my hard-disk Died? or its still alive?
PostPosted: March 8th, 2012, 13:07
Hey guys
First of all i have bad english, sorry about that
I have some problem with my hard-disk (HD103SJ)
When i start my computer it give me Blue Screen Of Death.
I started my computer in safe modus and did a Disk scan with DTI Surface Scanner
it gave me 2803 Errors.
And all of them are ''Data error (cyclic redundancy check)''
then i asked my frend and he sayed:
Im sorry to tell you this but, i think your hard-disk will die soon.
is this true guys?
will my hard-disk realy die soon?
how do i know this?
Is there a ANY Thing what i can do to fix this??
I dont wanna lose my hard-disk :(
Plz help me guys...
More info with CrystalDiskInfo;
CrystalDiskInfo 4.3.0 (C) 2008-2012 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Ultimate Edition SP1 [6.1 Build 7601] (x64)
Date : 2012/03/08 18:05:33
-- Controller Map ----------------------------------------------------------
+ ATA Channel 0 (0) [ATA]
- TSSTcorp CDDVDW SH-S223C ATA Device
+ ATA Channel 1 (1) [ATA]
- SAMSUNG HD103SJ ATA Device
- ATA Channel 0 (0) [ATA]
- ATA Channel 1 (1) [ATA]
+ Intel(R) 5 Series/3400 Series Chipset Family 4 port Serial ATA Storage Controller - 3B20 [ATA]
- ATA Channel 0 (0)
- ATA Channel 1 (1)
+ Intel(R) 5 Series/3400 Series Chipset Family 2 port Serial ATA Storage Controller - 3B26 [ATA]
- ATA Channel 0 (0)
- ATA Channel 1 (1)
+ Standaard Dual Channel PCI IDE Controller [ATA]
- ATA Channel 0 (0)
- ATA Channel 1 (1)
- JMicron JMB36X Controller [SCSI]
-- Disk List ---------------------------------------------------------------
(1) SAMSUNG HD103SJ : 1000.2 GB [0-4-0, pd1]
(1) SAMSUNG HD103SJ
Model : SAMSUNG HD103SJ
Firmware : 1AJ10001
Serial Number : S246J90Z937791
Disk Size : 1000.2 GB (8.4/137.4/1000.2)
Buffer Size : 32767 KB
Queue Depth : 32
# of Sectors : 1953525168
Rotation Rate : 7200 RPM
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 6
Transfer Mode : SATA/300
Power On Hours : 6228 uren
Power On Count : 997 keer
Temparature : 28 C (82 F)
Health Status : Waarschuwing
Features : S.M.A.R.T., APM, AAM, 48bit LBA, NCQ
APM Level : 0000h [OFF]
AAM Level : FE00h [OFF]
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 _51 0000000022B4 Read Error Rate
02 252 252 __0 000000000000 Throughput Performance
03 _72 _57 _25 000000002236 Spin-Up Time
04 100 100 __0 0000000003C4 Start/Stop Count
05 252 252 _10 000000000000 Reallocated Sectors Count
07 252 252 _51 000000000000 Seek Error Rate
08 252 252 _15 000000000000 Seek Time Performance
09 100 100 __0 000000001854 Power-On Hours
0A 252 252 _51 000000000000 Spin Retry Count
0B 252 252 __0 000000000000 Recalibration Retries
0C 100 100 __0 0000000003E5 Power Cycle Count
BF 100 100 __0 000000000079 G-Sense Error Rate
C0 252 252 __0 000000000000 Power-off Retract Count
C2 _64 _63 __0 0026000E001C Temperature
C3 100 100 __0 000000000000 Hardware ECC recovered
C4 252 252 __0 000000000000 Reallocation Event Count
C5 100 100 __0 000000000007 Current Pending Sector Count (THIS IS YELLOW,That means a Warring, Other all are Blue, good)
C6 252 252 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
C8 100 100 __0 0000000000FF Write Error Rate
DF 252 252 __0 000000000000 Load/Unload Retry Count
E1 100 100 __0 000000000406 Load/Unload Cycle Count
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 0040 3FFF C837 0010 0000 003F 003F 0000 0000 0000
010: 5332 3436 4A39 305A 3933 3931 3931 2020 2020 2020
020: 0000 FFFF 0050 3141 4A31 3031 3031 5341 4D53 554E
030: 4720 4844 3130 3353 4A20 2020 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00
050: 4000 0200 0200 0007 3FFF 003F 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 1706 1706 0000 004C 0040
080: 01FF 0028 746B 7F69 4123 BC41 BC41 4123 207F 004B
090: 004B 0000 FFFE 0000 FE00 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 4000 4000 0000 5002 4E92
110: 035F 92B1 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 003F 003F 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 101F 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 0000 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 60A5
Plz help me?
Ugur
 Post subject: Re: my hard-disk Died? or its still alive?
PostPosted: March 9th, 2012, 7:17
Try to clone your drive, sector by sector, using a tool (eg ddrescue) that understands how to work around bad media. Then use data recovery software on the clone.
PostPosted: March 9th, 2012, 8:24
@ugur3D,
This would be a very large number of unreadable sectors - if it was true - but it seems that the disk itself only knows about 7 currently unreadable sectors:
is this true guys?
Perhaps. Hard disks can fail at any time - sometimes you get a little warning before there is a catastrophic problem; sometimes you don't get any warning before a problem; sometimes you get a little warning, but the disk still continues to work for a long time afterwards. Many different behaviours are possible.
Which answer (a) or (b) below, applies to your situation?
a) Do you want to recover the data from the disk (whether or not you also want to try to "fix" the disk)?
or
b) Do you only want to try to "fix" the disk, but you do not care about the data which is currently on the disk (e.g. because you already have backups)?
PostPosted: March 9th, 2012, 15:01
I have no problems if i lose my data i just wanna my hard disk seeing alive.
you need to understand this, This is my first build Computer (First Motherboard,Videocart Etc...)
So all of this i buyed with my own money,
I see them like a frend :oops:
So i dont care about data i just wanna it alive.
PS: from another frend he sayed: Do i low-level-format that maybe can help it !
so i did that
I have downloaded and burned HBCD and did a hard disk low-level-format.
I hope this will work if not
PostPosted: March 9th, 2012, 15:13
OK - you don't need the data and you have already decided on a plan without asking here, so I don't see there is any need for further comments from me. Good luck with your plan, but remember to use backups for any important data :)
Users browsing this forum: Google [Bot] and 221 guests
