 Post subject: Seagate ST3160318AS firmware repair
PostPosted: March 12th, 2012, 5:18
I have a Seagate Barracuda 7200.12 drive. Few months ago it suddenly started giving very low speeds (<3 MB/s). I thought it was a firmware problem.So, I upgraded the firmware from CC38 to CC49 and it was back to normal. A few days ago it again went very slow. I thought re installing the firmware would do the trick. But the firmware update utility said that it wont download the firmware as it was already updated. The drive is still accessible, but gives extremely low speeds. Is there a way out to repair/reinstall the firmware?
Thnx in advance,
Bluefog68
 Post subject: Re: Seagate ST3160318AS firmware repair
PostPosted: March 12th, 2012, 14:26
Why do you think the issue is a firmware problem? Probably some physical issue with the drive.
Look at the SMART data and see if anything shows an obvious problem.
Backup anything important on the drive.
Data Recovery Cape Town
PostPosted: March 12th, 2012, 16:02
@bluefog68,
I completely agree with Nick_CT. Since you say it is still readable, I suggest you backup what you need from that disk now. Just to add a comment:
As Nick_CT said, it's unlikely that firmware is actually the true cause of your problem.
However, have a read of this thread to see why there is much more to firmware repair, then you might guess...
diy-what-the-big-deal-t12671.html
PostPosted: March 12th, 2012, 20:02
Could you upload a HD Tune read benchmark graph?
If it is a flat line, then your drive may be running in PIO mode. If so, then your SMART data may provide an explanation.
PostPosted: March 12th, 2012, 20:29
@fzabkar,
Agreed, those are good things to check, Franc :good: That hypothesis would seem to fit and would explain why the effect of the f/w update would only be temporary.
PostPosted: March 13th, 2012, 0:36
On .12 it is quite common. The problem can be physical or not but the fix is not by fw update. P.s. You may have 'something' in your pc that 'damage' the drive.
PostPosted: March 13th, 2012, 6:52
Thanks everyone for the response. I thought it was a f/w problem because it started to work fine after the update. By the way, i have already backed up everything on the drive. I will soon upload the graph.
PostPosted: March 13th, 2012, 11:40
I have attached the read benchmark test (HD Tune). HD Tune also shows that this device has unstable sectors(3) under "health" tab. What does this mean?
Thanks in advance
PostPosted: March 13th, 2012, 11:52
Here's the S.M.A.R.T. Data.
ST3160318AS-9VY2NLED-SMART.mht
HDDScan S.M.A.R.T. Report
Model: ST3160318AS
Firmware: CC49
Serial: 9VY2NLED
LBA: 312581808
Report By: HDDScan for Windows version 3.3
Report Date: 3/13/2012 9:18:43 PM
Num Attribute Name Value Worst Raw(hex) Threshold
001Raw Read Error Rate 1140990000000467-9220006
003Spin Up Time 0990970000000000-0000000
004Start/Stop Count 1001000000000000-03F7020
005Reallocation Sector Count 1001000000000000-0000036
007Seek Error Rate 05805400001100A6-899A030
009Power-On Hours Count 1001000000000000-01D1000
010Spin Retry Count 1001000000000000-0000097
012Device Power Cycle Count 1001000000000000-01FB020
183SATA Downshift Error Count1001000000000000-0000000
184End To End Error Count 1001000000000000-0000099
187Reported Uncorrectable Error 0870870000000000-000D000
188Reported Command Timeouts 1000990000000002-0008000
189High Fly Writes 1001000000000000-0000000
190Airflow Temperature 06605234 C 045
190Airflow Temperature Minimum06605234 C045
190Airflow Temperature Maximum06605235 C045
194HDA Temperature 03404834 C 000
194HDA Temperature Minimum03404813 C000
194HDA Temperature Maximum03404852 C000
195Error Rate0520450000000467-9220000
197Current Pending Errors Count 1001000000000000-0003000
198Uncorrectable Errors Count 1001000000000000-0003000
199UltraDMA CRC Errors 2002000000000000-0000000
240Heads Flying Hours 1002531AA1530000-05E7000
241Total Host Writes 10025300000096BC-80F5000
242Total Host Reads 1002530000002333-4832000
Current Pending Errors Count and Uncorrectable Errors Count show problems. :?:
Users browsing this forum: Google [Bot] and 60 guests
